Possible Feature Requests
Re: why the maximum PWM value is 64.
« Reply #20 on: May 06, 2026, 08:12:06 AM »
I don't understand why the maximum PWM value is 64. Does this mean a resolution of 128 isn't achievable? 64 feels like an unfamiliar value; it seems to offer only half the performance. Is it actually only half the depth?
Is the maximum value of 64 a design choice to reduce the number of times you have to turn the knob? I'd like a function to turn off the skip function that increases the value by 2, and be given a resolution of 128.
Pulse Width goes negative too. The full range is -64 to 64, a resolution of 128. Try turning the param to the left!
I see, so the total is 128. I understand.
Thank you.
Stack and Split
« Reply #21 on: May 06, 2026, 08:12:34 AM »
I'd like to be able to stack 1 voice and 3 voices, or 2 voices and 2 voices.
I'd also like to be able to split the keyboard.
This will broaden the possibilities for music creation.
Re: Possible Feature Requests
« Reply #22 on: May 09, 2026, 05:55:58 PM »
While the arpeggiator is playing, adjust the pitch. If I like the sound, press and hold the PROGRAM button and then press the INC button to stop the arpeggiator.
If the arpeggiator is active, please keep it playing.
Main OS : 1.0.0.1
« Last Edit: May 09, 2026, 06:16:39 PM by Jpro600k »
« Reply #23 on: May 09, 2026, 06:03:38 PM »
The arpeggiator records from the lowest note, but it doesn't play back as intended unless I press a key an octave higher.
It feels wrong to raise the pitch by an octave.
I want it to play back in the key I played it in.
Main OS : 1.0.0.1
« Last Edit: May 09, 2026, 06:16:21 PM by Jpro600k »
« Reply #24 on: May 09, 2026, 06:16:03 PM »
12: Even when LFO REV SAW is turned off, the LED does not turn off.
Is this a bug? It seems like it should be fixed.
Main OS : 1.0.0.1
« Reply #25 on: May 11, 2026, 11:09:09 AM »
I would really like the Hold button to also hold the current Aftertouch values, so arpeggios can become more lively. Should be relatively straightforward. In time, proper MPE implementation would be great. And FTLOG, please get rid of this tiresome verification process in the forum. Doing it on registration once should be more than sufficient for security. Otherwise, love your stuff. (Own an OB-6 and now proudly the FOURM...)
« Reply #26 on: May 18, 2026, 02:16:06 PM »
I’d like to also share the following suggestions, which I hope will help too:
[enhance] Hold mode: I also support the idea of sustaining the actual after touch when in hold mode. I’d further suggest supporting the following operation: short press to hold without after touch (like it is now), and long press to hold with after touch. It wouldn’t require any new Global Settings option then.
[enhance] Global Settings > Pot Mode: In addition to Relative, Passthru, and Jump, what about adding a new “Ramp” mode in order to prevent from hearing abrupt changes, and to produce a smooth evolving sound instead. This new “Ramp” mode would basically catch up the physical pot position (like in Jump mode) but only over a period of time. I believe ½ sec should be fine, otherwise you could provide hard coded ramp options, like “Ramp Slow” and “Ramp Fast”, I.e. [Relative | Passthru | Jump | Ramp Fast | Ramp Slow].
[enhance] pots and values rendering (OLED screen): In the case of Relative, Passthru (and the new Ramp mode suggestion), what about displaying the physical and the logical pot values on the screen to assist with the operation. I’d suggest changing how the pot values are displaying, from their current “regular name + integer value in a box” representation. Instead, consider a graphical representation, displaying a round dial with the name as a label somewhere (top or bottom), and the integer value in the middle, with the addition of a solid line needle for the logical position (the one that is currently used to produce the sounds), and a dash line needle for the physical one (the actual position of the pot). If not a round dial (say because of lack of pixel resolution to make it meaningful), at least consider a bar representation (there is ample space to insert a bar representation, or a needle over a linear horizontal scale, under the actual value box currently displaying)
[new] Global Settings > Show Pots (somewhat related to the other suggestions above): It seems not all pots are displaying their changing value. The new settings could be something like: [Off | Essential | All] with “Essential” being what it is now (only a few are displaying) and “All” being any pot, including the mod matrix ones. And if the new “Display Envelopes” option is active (see below), then any envelop related pot would be automatically excluded from displaying.
[new] Global Settings > Show Enveloppes: It might be very handy to have graphical representations of both envelopes on the screen (vertically stacked), or eventually stacked as layers (on each other with dash and solid line rendering). I’m thinking this could be helpful to people new to synthesizers to get started. This could be also helpful to visually understand the interaction and overlapping that exist between the filter and the amplitude ramps over time. A graphical representation with values in ms could also help a lot to fine tuning the ramps for certain sounds and needs. The new settings could be something like: [Off | Active Only | Both], with “Active Only” being a single envelop displaying depending on which pot is changing, and “Both” being the vertical and/or layer stacked representation which is described above.
[new] Global Settings > Show Filter (or automatic rendering): pretty much the same idea as for the envelopes, but this time for the filter, rendering a graphical representation of the filter curve with the resonance bump, along with a frequency scale. This could be a great learning help as much as a practical tool. If not automatic, the new settings could be something like: [Off | On].
DEBUG COMMANDS :5.Load Grobal does not work for me.
« Reply #27 on: May 20, 2026, 06:46:31 AM »
While holding down the up and down keys for Transpose simultaneously, press the GLOBAL button. Next, select 5 with the SELECT knob. Press INC button.
However,
Why?
« Reply #28 on: May 29, 2026, 11:55:21 AM »
Is it possible to add a feature to lock the program to prevent presets from being overwritten?
It would be helpful if we could manually lock it. Please disable automatic locking, as unlocking it is a hassle.
« Last Edit: May 29, 2026, 11:57:14 AM by Jpro600k »
« Reply #29 on: June 10, 2026, 03:33:19 AM »
this ramp mode is an excellent idea. I wonder why this hasn't been implemented in modern synths.
This mode would invite to happy accidents, where parameters change in an unexpected way, but without the parameter jumps which create mostly unhappy accidents.
« Reply #30 on: June 24, 2026, 05:06:02 AM »
I would like the range to be changed from 0-127 to around 0-999, so that it can be adjusted to the perfect point by slowly turning the large diameter knob on an external controller. I would also like this function to be added to the global settings as an extended option for value display, allowing it to be toggled on or off.
« Reply #31 on: June 24, 2026, 05:11:20 AM »
The sweet spot for the modulation section is concentrated at shallow values ​​for the three knobs, so I'd like an extension option to stretch the range from ±0 to 21 to ±0 to 64.
It would be great if the magnification level for zooming in could be adjusted up to around 10x.
It will certainly contribute to creating a delicate sound.
« Last Edit: June 24, 2026, 05:15:10 AM by Jpro600k »
KEYTRACK button behavior
« Reply #32 on: August 10, 2026, 09:33:54 PM »
Pressing the KEYTRACK button takes you to the settings screen, but the button's indicator light turns off when you do so. Is it a bug that the light goes out even when the "HALF" setting is currently in use?
It is great that you can instantly change values ​​by turning the knob while holding down the button; do all buttons labeled "AMOUNT" behave the same way? It seems the Velocity button works like that, too.
« Last Edit: August 10, 2026, 09:40:19 PM by Jpro600k »
Feedback on the value of each knob
« Reply #33 on: August 13, 2026, 09:07:17 AM »
I would like the LCD to display the value of each knob the moment it is adjusted. Immediate value feedback is essential, particularly for the modulation and aftertouch sections, as these are critical areas; I feel the same applies to the other sections as well.
Often, key sound-shaping settings are concentrated within a narrow range. Being able to see these values ​​would make the sound design process significantly easier. If this were implemented, it would improve usability and allow for the exploration of even better sounds.
« Reply #34 on: September 07, 2026, 10:36:56 PM »
Such a beautiful synth. If you made this poly chainable, man I think I could live without a p5. 8 voices of fourm would be a beautiful thing. Thanks for having this place!
