Any way of decresing number of voices?
KG
« on: August 05, 2025, 02:59:36 AM »
Hi - sorry for stupid/newbie question.
Recently I'm having fun with creating long lasting sounds (long 'release'). When I'm playing two voices at same time they create really nice distortion-like sound which sounds great. Unfortunately when I hit key for the next time (and more) it is starting to be a mess (3+ such sounds at same time does not sound great).
So... Trigon-6 has 6 voices (obviously ;-) ) and you can easily make it monophonic by turning on Unison with 1 voice only.
THE QUESTION:
Can you make Trigon-6 to be 2-voice poly synth? (or any other number up to 6)
I doubt but.... there is still a chance that I missed something in documentation or there is nice trick/hack to achieve that.
By curiosity - is there any synth able to do that>
  • 1687
Re: Any way of decresing number of voices?
« Reply #1 on: August 05, 2025, 04:26:53 AM »
The Prophet 10 rev4 has a 2-voice poly mode (the Prophet 5 r4 might also allow this mode but with 5 voices total you wouldn't get 3 voices in duo poly mode regardless).
Without knowing for sure the sonic characteristic you're referring to when you say "a mess", I'm assuming you're getting clipping...  so long story short, during sound design you pretty much need to gain stage each sound depending on how it is intended to be used for best results.  I think this is even more true with a 3 oscillator synth assuming you're using all 3 for any given sound.
So you have a mix knob on the Trigon for each oscillator... try turning down each volume knob incrementally in about the same amount, while playing chords with the number of notes you typically want out of that particular sound, and expect that the more notes played will require backing off of gain (whether per oscillator or the master vol of the synth) one way or another.
I'll cite the 3rd Wave as an example of another 3 oscillator synth... the user manual explains it well by saying the total level for all oscillators should not exceed a value of 100 (which is also the same possible max value for each knob on that synth) or you can expect distortion... so that could be 40/40/20 or other combinations that don't exceed 100.  On the other hand a *certain* amount can sound nice depending on the sound.  But even still if I have everything adjusted perfectly to taste on a 3 note chord then suddenly start playing 5 notes at a time with the same sound, the dynamics have changed and it may need some adjusting for that use case.... even if that's just turning down the master a bit, etc.
« Reply #2 on: August 05, 2025, 08:14:51 AM »
You can temporarily disable a voice by holding a key, and pressing glide and hold together. Do this until you have as many voices as you want. I believe you'll need to restart the synth to restore the voices, though.
« Reply #3 on: October 06, 2025, 12:12:59 AM »
THE QUESTION:
I didn’t realize the Trigon-6 had that little “hidden” voice-disable trick (glide + hold). That’s a clever workaround for experimenting with limited polyphony textures.
It’d actually be great if Sequential added an official “voice limit” parameter in the global menu, similar to what’s possible on the Prophet-10 with the 2-voice mode.
kpatz
  • 166
« Reply #4 on: October 18, 2025, 07:01:42 AM »
This might work as a workaround:  change your patch to have a long decay instead of a long release (set release to zero or low), then engage the Hold button and play your first chord and let it ring out.  When you want to play the next note/notes, just hit them and it will disengage the prior notes, and with a fast release, they’ll die out quickly.
g3o2
  • 180
    • My music
« Reply #5 on: April 06, 2026, 03:54:08 PM »
You mean poly unison on the rev4? That's actually 5 notes polyphony with 2 voices per note. There is also a simple 5-voices mode under globals menu 3.
