Output volume really low
Started by TheArtVark, June 29, 2025, 03:50:10 PM
8 Replies 13,803 Views
TheArtVark
Commerce
I just got a TEO 5. I understand has lower output volume than some other synths, but the difference with all my other gear makes me wonder if I may have an issue. I've made a basic program, turned on all OSCs, set the voice volume to 127, volume to max, all levels of overdrive etc but if I do no apply any gain on my mixer (SSL Big Six) the signal struggles to reach even -6db. If I turn the gain on the mixer up to +20db the lever does go up to 12db on the mixer but it seems strange to me that I have to apply so much gain to get to a level to match some of my other gear.
It's apples and oranges, but my Hydrasynth for is easely 10 DB  louder.
Is this low output to be expected? This is my first analog poly, I just don't know :-(
Mattog
Commerce
For your reference I also run my TEO-5 through an SSl Big Six. Currently I have the TEO's master volume at 3 o'clock and the trim set to minus 2 (-2) on one of the SSL's stereo channels without any gain issues. My signal chain is unbalanced TS cables into a balanced/unbalanced Samson patch bay with balanced cables from the PB to the stereo inputs on the SSL. My question is are you using balanced cables from your TEO or unbalanced as the former can cause issues with unbalanced instruments. Also, are you using a patch bay? I thought I had a problem with my Prophet 10's volume level until after lots of head scratching I discovered a jack into my patch bay needed just one little extra push to seat it properly into the socket. I know this is all basic stuff, but even simple things like this can still catch you out.
TheArtVark
Commerce
Interesting, we have almost the same setup. I have a Samson patch bay too, I assume it is the same S-Patch Plus as this is the only one they make :-)
I did try several channels on the patch bay, I don't think it is a bad connection.
I think a crucial difference may be that I run a dual mono to stereo jack from the TEO to a single patch point, and from there a single stereo to dual mono jack to the SSL. So all unbalanced. I am also breaking the normal by patching into the front (lower) jack, but I don't think that should make a difference. The dual mono to stereo does, maybe?
I will try running some unbalanced cables directly from the the TEO to the SSL and report back, thanks for the input!
TheArtVark
Commerce
Aaaaand nope, same result. I could try finding some empty patch points in my patchbay and doing exactly the same as you have: unbalanced to that, then balanced to the SSL... Not sure how that would make a difference though.
I'm also noting that the headphone is not as loud as would expect either. Plenty loud to play around with at home but in a live setting I doubt it would make it above the guitars, for example. The same headphones on the Hydrasynth go loud enough to be almost painful.
TheArtVark
Commerce
OK, I figured I may as well try. Two unbalanced cables straight from the output to my Mordax Data in oscilloscope mode. Again basic progam, filter fully open, OSC1, 2 , Sub and Noise open and Sustain at max. The signal barely hist 1 volt, so peak-to-peak is a very meagre 2 volts.
Mattog
Commerce
Yeah sounds like the unit might be faulty. Have you tried a calibration or even reinstalling the operating system? You never know. Otherwise contact Sequential and see what your options are.
gus
Administrator
Full Member
It's worth noting that the SEM topology allows for a wide dynamic range, from a single oscillator to all 5 oscillators in unison with resonance cranked. The analog signal is digitized post filter - the TEO is a bit lower in the analog domain to avoid clipping when entering the digital domain. It's still possible to clip in extreme circumstances and when the program volume is maxed out.
Not sure if that is the case here, but thought I would mention! We don't see hardware faults where the output is way lower very often on this instrument, so it could be something setup related. If you have another interface to test with, that always helps for troubleshooting. We also recommend testing with the least amount of connections possible, IE synth to interface to computer.
If you still feel like something is off, go ahead and reach out to support@oberheim.com and we'll help you out.
TheArtVark
Commerce
I have contacted support, and they have asked me to re-calibrate and make a recording of just the basic program without any thing touched except the main volume open. I did and sent it just now. Iirc it peaked at -34 dB in my DAW, so....
I have also already tried different channels on the mixer, different cables. And other instruments on this mixer work fine. I just plugged my Moog Grandmother with a random patch into the the same channel just (left side, mono of course), thats about 18db louder.
It is very weird, I think it sounds OK, if there was something seriously wrong with the output stage you would expect something to be distorted or something.
Ah well, the people who know what they are doing are on the case now :-)
TheArtVark
Commerce
Update for anybody coming across this thread in the future:
After looking it my recordings Oberheim support said Send the synth back, which I did. Thomann sent a new one straight away and it is just as loud, maybe a little bit louder. So while the synth is probablynot as loud as many others, this looks like it is mainly a user error. I moved to the SSL from a very different (cheap) mixer, I think I am just reading the metering wrong. And that is it perfectly normal to have to add some gain and turn on EQ to get OK input levels.
I don't think it is a wiring issue or anything like that, just me having different expectations and a lack of knowledge :-)
Kudos for Oberheim support and Thomann. I was not happy, they handled it well and now I know everything is fine.
