Newest Prophet 5/10 Main OS 2.1.0 and Panel OS 1.1.3
gus
  • 301
« on: May 27, 2025, 04:38:27 PM »
OS updates are compatible with both the Prophet 5 and 10 keyboards and modules. YOU MUST LOAD THE MAIN AND PANEL UPDATES SEPARATELY AND POWER CYCLE AFTER EACH INDIVIDUAL UPDATE COMPLETES. After updating and power cycling the Main OS will display as "2.1.0". After updating and power cycling the Panel OS will display "1.1.3".
**After loading the Panel OS, wait for the display to read "rst" before power cycling**
To check currently installed Main OS, hold GLOBALS and press the program "1" button. To check currently installed Panel OS, hold GLOBALS and press the program "2" button.
When the OS file is transmitted to the synth a count from 0 to 100 will be displayed on the synth's main display to indicate reception of the OS file.  Once the count reaches 100, a second count from 10 to 0 will commence indicating writing of the OS to internal memory.
**DO NOT POWER THE SYNTH DOWN WHILE THE SECOND COUNTDOWN IS ACTIVE**
The synth will return to normal operating after the writing stage completes.  Power cycle the synth off and back on to finish the update.
ALWAYS BACKUP YOUR IMPORTANT WORK VIA SYSEX DUMP BEFORE ATTEMPTING ANY OS UPDATES!!
Not that we're expecting bad things to happen, but always better safe than sorry. Just remember, you're never going to say to yourself "Man, I wish I hadn't backed that up..."
We do not recommend using the following MIDI interfaces for sysex transfers as we have had multiple users experience problems with them:
    Native Instruments Maschine
    Digidesign Mbox/Mbox2
    Digidesign 001/002
    CME U2MIDI
To check if the OS update was properly installed, restart the unit, hold the GLOBAL button and press the 1 button.  The 3 digit main OS version number will be shown on screen.
If your OS update failed:
1. Update your MIDI drivers for your MIDI interface to the latest or last known stable version
2. Try alternate speed settings: transfer speed settings as low as 25% and as high as 100% have worked for some users when 80% did not
3. Try an alternate MIDI interface. The M-Audio MIDI Sport Uno works well here and is relatively cheap
4. In Windows with MIDI OX on Windows XP:  Try doubling or quadrupling the Size setting to start, and halving/doubling the number of buffers
5. Search google and/or forums for the company that produces your MIDI interface to see if other users are having similar problems with Sysex transfers and whether there is a solution specific to your interface
6. If you are on Windows XP, try another OS or machine. Although it's not ideal, we have had less problems with Mac OSX and Windows 7. Windows XP has known issues with sysex transfers
**INSTALLATION NOTE: It is recommended to reset globals and clear calibration after updating from any OS below Main 1.5.0.  You will need to re-tune the synthesizer from scratch following the update.
RESET GLOBALS : hold RECORD and press GLOBALS
CLEAR CALIBRATION: hold RECORD and press TUNE
gus
  • 301
Re: Newest Prophet 5/10 Main OS 2.1.0 and Panel OS 1.1.3
« Reply #1 on: May 27, 2025, 04:40:32 PM »
The official P5/P10 Main OS 2.1.0 and Panel OS 1.1.3 are out now! The files, instructions, and addendum can be found on our (refreshed) website at the link below.
https://sequential.com/support/download/prophet-5-10-operating-system/
