How is the EPM570T100I5N programmed after being mounted on a PCB?
Details about EPM570T100I5N: https://www.emsfpga.com/productdetail/epm570t100i5n geometry dash spam
The EPM570T100I5N (a MAX II CPLD) is typically programmed in-system via the JTAG interface. Once it’s mounted on a PCB, you’ll need to ensure the board exposes the JTAG pins (TDI, TDO, TMS, TCK) via a header or test points. Use Intel’s USB-Blaster along with Quartus Prime software to load your .pof or .jic file.
Make sure the JTAG chain is properly terminated and powered during programming. Also, double-check the nCONFIG/nSTATUS lines if used in your design.
