« Reply #1 on: October 03, 2025, 09:36:44 AM »
Under the Global menu there is a parameter:
Program Copy Utility
Enables layer A or layer B of a program to be copied to layer A or B of the same or a different program. The top line displays the
current bank and program. Use increment (+) or decrement (-) to choose the layer to be copied. Then use SELECT to select the destination bank, program, and layer and increment/decrement to change the values.
This function is also available using the free Soundtower editor, where you are able to copy the parameters from a Program into a chosen bank of another Program, (see the Edit Menus - Import Layer).
Sixcontrabass: - Prophet 10 Rev4, Prophet 12, DSI Tetra, ESQ1, Yamaha FB01, Korg 05R/W, Cheethah MS6, Cheetah SX16, EMU e5000 Ultra, Roland Super JV, Novation A Station, Waldorf Blofeld, Creamware B4000, Creamware PRO-12 ASB, Behringer Dimension D, Neutron, Pro-1
