TEO5 LFO 1&2 amount values jump
Started by camillomuc, March 04, 2025, 02:54:39 AM
4 Replies 17,489 Views
camillomuc
Commerce
Hi, the amount of LFO 1&2 values jump. This actually is most impacting if the amount parameter is set to small values (1-3). E.g. if set to 2 or 3 it jumps between 1 an 4. Does anyone else has this issue?
gus
Administrator
Full Member
Thanks for reporting this here! We are aware of this software issue in support and we are actively working on a fix. If you haven't already reported the details to support@oberheim.com (issue description, serial number), please do so as it helps set priorities and lets us notify specific customers when there is an OS update available.
Apologies to any customers dealing with this - we should have a solution soon.
camillomuc
Commerce
Quote from: gus on March 04, 2025, 10:20:11 AM
Thank you much! I´ve just sent it to support@oberheim.com
camillomuc
Commerce
I´ve tested the new beta now. The handling of the pots is much better now (still not perfect, but fairly usable). Thank you much for that, team OBERHEIM!!
camillomuc
Commerce
For those who are concerned about that issue:
Imo this is just an issue if you need a precise lfo frequency or amount. If so there is a workaround: You can set the lfo to zero so it can't jump and choose a mod slot. Than set source to dc and dest to lfo freq or amount. So you have precise control on the lfo.
