Why mod dest "Noise" is mono?
Started by camillomuc, February 12, 2025, 07:25:11 AM
8 Replies 11,658 Views
camillomuc
Commerce
The modulation destination noise (level) seems to be just mono.
To use it for percussive sounds like suggested on page 23 of the user´s guide only makes sense with mono/unisono sounds. I´d like to modulate noise per voice.
Does anybody know a workaround or is it possible to get a polyphonic noise mod dest with an update?
Quatschmacher
Full Member
My guess would be that there might be just a single global noise source that is mixed in with audio from any gated oscillator(s).
camillomuc
Commerce
Quote from: Quatschmacher on February 12, 2025, 07:44:43 AM
That was my thought, too. The noise osc seems to be mono. But it is routed per voice thru env1+2. So why can´t it be also routed per voice as a mod destination?
Quatschmacher
Full Member
Quote from: camillomuc on February 12, 2025, 07:55:54 AM
It could have 5 outputs from the noise into the voices. That is still one single source that can only be affected monophonically.
BT
Agents
Jr. Member
Greetings! To confirm, in the TEO-5 there is a single noise source mixed in with the 10 oscillators from the five voices. This is a common approach in analog synth design.
camillomuc
Commerce
#5
Quote from: BT on February 12, 2025, 10:27:01 AM
Ok, I understand. But why is just voice 1 affected by mod and not the other voices? Seems to be no relatch. Try to aux env as mod source and noise as dest eg. Noise only appears at every 5th tone
BT
Agents
Jr. Member
This is because Noise is a mono mod source and will not function as expected when assigned to poly destinations.
kpatz
Jr. Member
Quote from: camillomuc on February 12, 2025, 01:15:47 PM
When sending a poly source (like an envelope) to a mono destination (like noise level), only one of those poly sources gets sent, usually the 1st note played.
Mono destinations have a shared CV from the DAC to the affected VCA(s) so there's no way to make them per voice without a hardware change.  Though, a firmware update could combine or assign "most recent voice's" mod source to the destination so every voice's envelope can trigger the noise.
camillomuc
Commerce
#8
Quote from: kpatz on February 13, 2025, 05:46:14 AM
Good suggestion! That would be useful eg for sounds with a short noise attack and slower decay/release by the poly  envs/oscs without voice stealing which would occur when playing with mono/unison instead. Thinking about pluck sounds like a harp, marimba etc
