Low Output Volume
Low Output Volume
« on: February 09, 2025, 08:46:57 AM »
How are ya'll dealing with the low output volume on the OB-X8? It's been a frustrating experience here.
I've added gain at the preamp stage, but found that it also raised the ground hum noise levels quite noticeably, so I added a Radial JDI to the chain, which seemed to fix that issue.
But I've been experimenting with different live setups, such as directly connecting the OB-X8 to a Model 1.4 and have found that it just can't drive even the unbalanced inputs of the 1.4. So now I'm looking at whether I need to get a signal driver like the J+4 to add to the chain.
I feel like this really shouldn't be necessary -- it's not necessary with any other piece of gear that I own. Any ideas?
« Last Edit: February 09, 2025, 09:32:30 AM by mattling »
Re: Low Output Volume
« Reply #1 on: February 09, 2025, 10:37:37 AM »
I own the OB-X8 keyboard and two modules, and none of them have low output volume problems.
« Reply #2 on: February 09, 2025, 04:50:15 PM »
Hey there! I totally get the frustration with the OB-X8 output levels. Have you tried using a dedicated DI box like the Radial Pro48? It’s designed to boost signal strength without adding noise. Also, make sure your cables are high quality and shielded to minimize hum.
Das Leben ist nur ein Spiel, aber ich werde es ernst nehmen und niemals davonlaufen sprunki | Cookie Clicker Unblocked | unblocked games | zhihu |
« Reply #3 on: February 09, 2025, 04:53:42 PM »
Hello... it is a little quiet, but noise might be something else with your wiring, as mine is running straight into Audient Evo 16 line-in, with +10 DB gain boost and volume on OB-X8 maxed, resulting between -6 and -12 DB on the faders for the first patch "It's an Oberheim!".
At first, I did wonder how that would go, but there is no audible noise floor, hum, etc.  Nothing even appears on a zoomed-in meter.  Just super clean output, more so than some of my other hardware which can get to -60 DB or more on the meters for noise on the same interface.
Assuming you tried unplugging the USB port and re-check the meter?
Teiko
« Reply #4 on: February 12, 2025, 03:10:18 PM »
From my experience the X8 has a very high dynamic range. Especially when you add more waveforms and crank up the resonance suddenly you get a much louder signal. This means you actually need the headroom.
