Split+ mod1 / vibrato lfo not working
« on: February 02, 2025, 01:50:11 PM »
I'm having trouble understanding some part of the synth if someone can help...
When using split+ mode, initializing a preset will disable mod1 / vibrato lfo and pitch bend. It just doesn't work even the rate of the lfo won't change when turning the knob. It is also disabled via modwheel. I found no way to make it work. This is the same for both lower and upper layer.
When in split+ but loading an existing preset for upper or lower layer. Mod wheel and pitch bend works, but I can't change the mod1 / vibrato rate or depth via the knobs on the panel. It seems those parameters are not accessible from the front panel.
I'm really confused about this. My understanding of the manual is that the same functionnalities are available in split or split+ mode...
Maybe it's a bug or something? Let me know if my explanations are not clear...
