Multimode preset problem
« on: January 28, 2025, 12:33:00 PM »
Hey there ! it seems like i can't change the preset of my layer B when my Local control is off and m'y multimode on... Someone know how to fix this ? Is it normal ?
I've try the method of the MISC PARAMS, when local control is on it work fine but not when it's off. The name don't Scroll but the number of the preset and bank yes however the sound don't change.
Thanks !
« Last Edit: January 28, 2025, 01:00:23 PM by kmio »
Re: Multimode preset problem
« Reply #1 on: January 28, 2025, 11:26:00 PM »
You don't mention which sequencer you use?
With layer B activve REV2 should send on midi channel 2 consequently in multimode.
- I have not checked this myself
- but use some midi monitor in sequencer or separate program to check that
Many sequencers work a bit different
- some require to set to omni mode or all incoming with be put on like channel 1
- some are default to midi channel 1
In Cubase set midi channel to Any and don't select a specific channel.
Some sequencers work different on monitoring and when recording as well.
Just some ideas....
