MOD functions stopped working
Started by frekvens, January 23, 2025, 03:14:06 PM
5 Replies 7,120 Views
frekvens
Commerce
I first noticed yesterday when I did a Basic Program, and the first thing was Voice spread to Panning at +127. No Voice spread happened...
Restarted, tried again, didnt work.
I changed the program to one I knew had voice spread on. It was wide. So tried again with basic program and voice spread. Bingo! Wide voices!
Today after work; my wide, voice spreaded program I saved from yesterday wasn't wide anymore.
Been troubleshooting for hours.
Turns out when it is connected with USB midi (OR regular midi) Any of the mod stuff wont work.
Voice spread to noise, filter, panning etc - nothing happens!
Velocity seems a little odd to, but aftertouch seems to work by normal. And the small amount of Modwheel to LFO that is there by default on a Basic program works, but nothing happens if I add to the amount.
With any midi cable unplugged and I switch to All Local On, the mod section behaves like it should.
I've read this troubleshooting guide:
https://support.sequential.com/hc/en-gb/articles/5313427315346-Take-5-Troubleshooting
About the Bootloader mode - what can I do from there? I can enter bootloader mode but then what?!
kpatz
Jr. Member
Anytime something doesn't work right with MIDI or USB connected, but does with it disconnected, it's either a midi loop or something incoming over midi (from your DAW or another device) that's interfering.
frekvens
Commerce
I went to bed thinking about if it was a midi loop.
But Shouldn't (?) I be able to:
- Set all Local off on Take 5
- Have MIDI track in DAW with Take 5 as MIDI in and MIDI out.
- Then I can play on Take 5. In this case "MIDI Control" in Global setting on Take 5 needs to be on, otherwise I can't play on it.
Also MIDI channel in DAW needs to be the same as Take 5.
- In this case, mod section does not affect the sound.
Work around is to switch to Local On.
Just enable a MIDI input on the track in DAW. Disconnected MIDI out.
Record MIDI data.
Disconnect Midi in and connect Midi out so I can send the recorded midi to Take 5.. in this case I can't record filter sweeps or other cc:s etc since I disconnected the midi in...
Local off on a hardware synth and MIDI in/out enabled on a track usually have been working for me for all synthesizers I have - but I maybe I got it all wrong?
frekvens
Commerce
Otherwise - how am I supposed to playback a MIDI pattern and then record knob-movements?
frekvens
Commerce
Well after going through Global settings punctual, a little bit back and forth one some settings, I now feel Take 5 is back to "normal state" again.
I will believe this was a bug after I switch to Din midi and used a drummachine as master, and back to working in DAW with miditracks.
Now it's been stable, restarted, and stable again.
Thank you for your answers :)
