Arp not in time with external clock. Is this a known issue & possible to fix?
Started by JohnnyPaycheck, January 18, 2025, 05:25:51 AM
4 Replies 18,756 Views
JohnnyPaycheck
Commerce
Hi there,
I'm a new Take 5 owner so forgive me if I'm asking things that have been covered before, but I can't find a clear answer to this.
I've synced midi clock with my DAW.   I've set 'Arp Beat Sync' to quantise. But..  when I play the arp, it quickly drifts out of time, even on a 1/2 clock divide (which is a really easy way of seeing it if it stays in time).
Is this a known bug or am I missing a key setting here?
Thanks for reading and thanks for your help.
lewisfrancis
Jr. Member
I'm not seeing any sync drift here, using USB MIDI and Logic as the master clock. Are you on the latest firmware?
JohnnyPaycheck
Commerce
Yes on latest firmware but only using the DIN midi connection to connect to my DAW (Luna) via a midi hub, so I'll try USB midi and see if that fixes it.
lewisfrancis
Jr. Member
Quote from: JohnnyPaycheck on January 21, 2025, 11:42:49 PM
FWIW Logic doesn't appear to send MIDI clock by default -- are you sure Luna is sending clock?
emilyjohnson63
Commerce
Quote from: JohnnyPaycheck on January 18, 2025, 05:25:51 AM
Hi there,
animal rampage
I've had similar clock drift issues with other synths when using DIN MIDI through a hub. Switching to USB MIDI often resolved it for me too, which points to a potential issue with the hub or the way the clock signal is being handled over DIN.
