Hello everyone,
I need your help to recreate a patch on Prophet 5.
I'm not an expert in sound design. A long time ago I loved one patch I had been using with my VST Pro-53 from Native Instruments, which is based on Prophet 5.
NI Pro-53 is no longer compatible with my macbook setup. I've found another fork from NI Pro-53 source code which is called Pro-54 from CMajor. The sound sounds exactly the same to me.
As the user interface is quite the same as the Prophet 5, I tried to recreate this patch on my Arturia Prophet 5 VST which is quite close to the original hardware sound from what I've read.
But the patch sounds completely different. The LFO seems to be the problem but I'm not sure at all.
Here is the Pro-54 (web browser designed emulation of Prophet 5) :
https://cmajor.dev/assets/example_patches/Pro54/index.htmlThe patch I'd like to recreate is #148 Pad Oblique
Do you achieve to be close to this sound by recreating this patch on your own Prophet 5 ?
Do I miss something ?
Any help would be very appreciated.
Thanks a lot !
Mathieu
