LFO to VCA level destination, noise problem
Started by giovio, October 27, 2016, 04:30:17 AM
7 Replies 13,091 Views
giovio
Commerce
Hi guys,
I am creating a sound with a bouncing effect that uses the modulation of the VCA by the LFO using a rev saw shape.
After triggering the sound I can hear a continuous background sound associated with that voice and, I suppose, due to the VCA triggering by the LFO that persist also if the sound has a very short decay.
This background sound stops only if I activate simultaneously the 6 voices in order to steal the voice associated with that triggered sound.
There is any way to avoid this artifact? I know I can use a different approach for example using the delay to simulate the same bouncing effect, but then I will have some restrictions on the sound shaping possibilities.
Thanks, regards
Stefano
Monocon
Commerce
Set up an additional envelope controlling the lfo amount...
John the Savage
Full Member
Further to what Monocon said, if you're using the mod matrix, you just need to set up a second mod slot, mapping the amp envelope (or any envelope for that matter) to control the amount of whichever mod slot you used to map the LFO to the VCA.
Cheers!
cbmd
Global Moderator - Sequential
Full Member
Actually, the best way to stop the 'artifact' is to modulate the AMP ENV AMOUNT parameter in place of the VCA LEVEL destination.  When the VCA is modulated, is will set the minimum amount that the VCA is opened on all voices regardless of the VCA envelope curve.
Product Designer
John the Savage
Full Member
Quote from: cbmd on October 27, 2016, 01:16:28 PM
Hmm... I've never thought to do that.  Good tip.
Cheers!
giovio
Commerce
Thanks guys what suggested by cbmd works very well, there is just to consider a different behavior of the envelope I have to use ADSR instead of the AD mode but it is OK
Regards
muleskinner
Jr. Member
You may also get away with an AD envelope with ridiculously long peak hold - good for syncing the length of the effect to the track without having to worry about note durations.
giovio
Commerce
Quote from: muleskinner on October 28, 2016, 01:45:57 AM
Yes definitely better muleskinner, thanks guys... this machine is amazing!
