Prophet Rev 3.2 Owner Needed to help Transfer My Preset
« on: October 30, 2024, 07:25:17 PM »
Prophet Rev 3.2 Owner Needed…
I sold my Prophet 5 Rev 3.2 (with Sequential standard MIDI kit) in preparation of getting a new Rev 4.
I assumed the Rev 4 could read my Rev 3.2 Sys-Ex patch data, but Sequential says it is not possible with the Rev 4 at this time (and near future).
Now I have no way I transferring my Rev 3.2 Sys-Ex data into Repro-5 to see the settings.
Is there anyone out there that can help me ?
I have a Logic Pro Sequence only containing one track with the Rev 3.2 Sys-Ex patch data for a single preset.  I could also save this sequence file as a Standard MIDI File if you do not have Logic Pro.
If someone play the Sys-Ex data into their Prophet Rev 3.2 and then export that preset as an audio preset file in WAV format - I can the import that WAV file into U-he converter and see the settings.
Is anyone out there willing to help me try this ?
Thank You
Nunucello
Re: Prophet Rev 3.2 Owner Needed to help Transfer My Preset
« Reply #1 on: November 01, 2024, 03:49:59 PM »
Here's an update....
I was able to get Sys-Ex Librarian to receive the data.
But it looks like the Sys-Ex data is pretty much empty.
Size = 17 bytes
Size Decimal = 17
Size Hex = $11
F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 F7
Chesksums
MD5 = 9d813ef96b9f39b46ca3e23b2ebe5509
SHA-1 = f55e580abce9296b5d259281b0a5fa692c1b9b1c
« Reply #2 on: November 01, 2024, 03:52:15 PM »
At the time when I recorded the Sys-Ex data into Logic, I did the following with my Prophet 5 Rev 3.2
1. Hit Record on Midi Track in Logic
2. Press the preset button, ex.  for preset 27, “7” just for that preset.
I had read that Prophet Rev 3.2 Sequential MIDI Kit would transfer Sys-Ex data when following that procedure.
Look like it only did maybe a Program Change Event.
I don't know what went wrong here or what happened.
« Reply #3 on: November 01, 2024, 03:58:01 PM »
See screen grab.
« Reply #4 on: July 31, 2025, 07:39:18 PM »
With the significant amounts of new Rev4 Prophet 5 synths being sold it would make even more sense now for someone to formulate a translation algorithm to convert vintage Rev3 Prophet 5 patch data into patch data compatible with Rev4 Prophets. Perhaps someone with both a Rev3 and Rev4 Prophet 5 could even use AI (ChatGPT / Gemini / etc) to assist them. By setting up a variety of patches (utilizing all of the Prophet 5's capabilities) in duplicate on both the Rev3 and Rev4, under analysis a recognizable accurate transfer function would emerge.
Senior member for many years on the old deleted DSI/Sequential forum
« Reply #5 on: July 31, 2025, 07:44:11 PM »
Here's how I got around it:
1. I used U-he Repro Converter to import my Rev 3 patch data (audio code) and open it in U-he Repro.
2. Took a screen grab of the settings in Repro and dialed them into my Rev 4
3. It ended that my Sys-Ex date I recorded with my Rev 3 was just the preset numbers.
