Broken table of contents
0x80
« on: October 13, 2024, 12:57:44 PM »
Do you have a working table of contents in the manual P5/10 manuals? All links take me to the top, which is really frustrating. It's not like this synth came out yesterday. What's going on?
Re: Broken table of contents
« Reply #1 on: October 13, 2024, 02:07:33 PM »
Has it ever worked like others?  :-\  (Like the Kemper Profiler Manual for example)
To get to desired page write the page number in the little box in upper left corner   :)
Cheers !
« Last Edit: October 13, 2024, 02:16:42 PM by HockeBocke »
0x80
« Reply #2 on: October 13, 2024, 10:35:10 PM »
Not sure what you mean by that. I have owned a lot of gear, and this is the only manual I can remember in recent history that has a broken ToC.
I use Preview (the MacOS built-in PDF reader) and I do not see the page numbers, unless I keep coming back to page 5 where the ToC is printed.
My OB-X8 manual doesn't have this problem, nor did my Prophet6, so the people at Sequential working on manuals should have enough experience to get the basics right.
« Reply #3 on: October 14, 2024, 02:02:02 AM »
I meant "has it ever worked like others?" (manuals) ........   ::)
It does not work with Mac OS preview ( like other pdf manuals ) but if you open
the manual by clicking this link
https://davesmith.wpenginepowered.com/wp-content/uploads/2021/02/Prophet-10-Users-Guide-1.4.pdf
you will come to this page (see picture) and there is the box (marked with red circle) where you enter the
page number you want to read .....
0x80
« Reply #4 on: October 14, 2024, 10:11:11 PM »
Thanks for offering help, but being able to jump to a page is not the main problem.
I think every PDF reader probably has that kind of feature. In preview it's "go to page" / option-cmd-g
The problem is not knowing what page to jump to. Without a working table of contents in the sidebar, you need to keep coming back to the page where it was rendered.
I considered using go to page as a workaround, and found that if I jump to page 1 (which is the minimum in Preview) it takes me to Chapter 1, so I can't even jump to the rendered ToC  >:(
Maybe I have high standards, but I find this unacceptable for an expensive professional device produced by a fairly big company. It shouldn't be that difficult to fix. It's an essential part of writing a decent manual, and many years have passed since this manual came out.
« Last Edit: October 14, 2024, 10:14:22 PM by 0x80 »
« Reply #5 on: October 14, 2024, 11:11:57 PM »
The P5/10 comes with a printed manual as well (but not the Oberheim OB-X8 for some reason) that is a good resource to read now and then.
0x80
« Reply #6 on: October 15, 2024, 12:45:46 AM »
Ah, thanks for reminding me! There was one taped to the bottom of the box. I forgot about it. I will use that then.
« Reply #7 on: October 15, 2024, 02:36:42 AM »
The first pages in the manual is numbered with Roman letters, where " V " is page 5 ( first page of TOC )
so if you enter the letter "V" in the box you get to the first page of TOC ....   ( Picture #1 )
If you click the most left "box" the sidebar opens .... If that's what you meant  ( Picture #2 )
It's a "workaround" I know, but I think the "bug" in the pdf manual is not prio #1 for the staff .... sooo   ::)
0x80
« Reply #8 on: October 15, 2024, 07:07:31 AM »
Nice that'll do!
I was indeed talking about that sidebar, but then switch to ToC instead of pictures. That's the most convenient way to navigate a PDF, but in this case those links do not work.
Anyway, I have a paper manual now, and I can jump to/from the rendered ToC, so I think I will survive  ;)
Cheers
« Reply #9 on: October 15, 2024, 08:59:09 AM »
We will all survive .... for a while   ::)
Note :
All new features are not covered in the manuals ....
( Poly Unison mode PU2, Round Robin mode, 5 voice limit mode,
Q-compensation, Aftertouch sens. and more )
Refer to this link and scroll down for more info.
https://forum.sequential.com/index.php/topic,4873.0.html
Cheers !
