Take 5 program editors
« on: October 12, 2024, 06:26:43 AM »
What Take 5 program editors are out there - only SoundTower? If so, think I'm going to throw together a Ctrlr panel, since that has worked well for me (both standalone and VST).
Just got a Take 5 and I'm already annoyed at not being able to see the value of saved program parameters without turning the knobs back and forth until that tiny dot appears in the LED readout. (The LED is much smaller than on the Prophet-5, Prophet-6, etc. so it's harder to see.) The Rev2 shows current parm values in the OLED display. Even the Mopho x4 shows saved and current values in its display. The Take 5 *has* an OLED display, but that will only show values for parms which do not have a knob - sheesh.
Re: Take 5 program editors
« Reply #1 on: October 12, 2024, 11:35:57 AM »
Pretty sure SoundTower is it -- Midi Quest has a librarian, but not an editor.
« Reply #2 on: October 12, 2024, 07:49:26 PM »
Ok thanks ... got a decent amount of the panel working already. I was particularly interested to see about usage of the 16 mod matrix slots - there are actually some factory programs which use most or all. Also noticed some programs have the first few slots used and then slot 16 is used - not sure I would have thought about that when just looking at the slots one at a time on the synth (I wouldn't necessarily scroll all the way to 16 to check on every program).
« Reply #3 on: October 27, 2024, 08:43:02 AM »
the Ctrlr panel is now available (free) at  https://github.com/synthmutt/CtrlrPanelSequential
« Reply #4 on: October 27, 2024, 10:55:10 AM »
Nice, and thanks! Took a quick glance over the doc and it looks quite useful, possibly could replace the Soundtower PlugSE in my workflow.
Do you have any advice or get started links for Ctrlr newbies?
« Reply #5 on: November 25, 2024, 08:53:23 AM »
Thanks a bunch for sharing.
BTW: I eventuall hacked together a panel for Take 5 and Propht 5 Rev4. Both are buggy and only display patches of the snyths, but as such, they servied me extremely well to learn about analog synthesis.
Cheers,
ce
« Reply #6 on: October 01, 2025, 06:56:38 AM »
not an editor but free librarian (which helps a lot and is superfast):
https://f0f7.net/fe/#/SysexLibrarian/SequentialTake5
« Reply #7 on: October 01, 2025, 10:18:41 AM »
Meanwhile there's also a Github repository hosting Ctrlr panels for several Sequential Synths:
« Reply #8 on: May 18, 2026, 02:27:33 PM »
Thank you for sharing these we all of us!
It seems you're covering most Sequential instruments already, except the latest Fourm, for which I've started looking into a panel but haven't found any yet (except Soundtower).
Prior loosing myself in trying to learn and mess with the "programming side" of it, I was wondering whether you're also planning a CTRLR panel for the Fourm already?
