Arp notes when pressing a key multiple times fast
Started by BasementRiffs, September 18, 2024, 08:45:09 PM
2 Replies 9,053 Views
BasementRiffs
Commerce
Why is it that when I press a single key repeatedly it plays the sequence of arp notes instead of playing the same actual note of the key over and over again.  This is kind of annoying.  Arp is off and I am not holding down a single note.  I am pressing one key repeatedly.  It should play the note of that key over and over again.  But instead it plays the notes of the arp sequence and the Arp is turned off.
How do I shut this off???
kpatz
Jr. Member
#1
I'm not sure I understand.  You have the arp and sequencer both off, you hit the same key repeatedly and get different notes?
The only ways I can see something like this happening: (1) your voices are out of calibration, causing each voice to sound like it's playing a different note (do a voice calibration from the menu).  (2) you have something connected via midi and it's sending arpeggiated or sequenced notes to the synth in response to you striking the keys.  What do you have connected to your Take 5?
Lastly, this IS a Take 5 you're talking about, right?  Some paraphonic synths let you tune each voice individually and run in a round robin fashion in paraphonic mode.  Moog Matriarch is one such synth, and perhaps the Sequential Pro 3 does too (I don't have one so I don't know).
Edit: I just thought of another cause: mapping Voice Spread or Random to pitch in the mod matrix could lead to this effect as well.  Does this happen on all patches or just one?  Also if you have Vintage turned up, it can cause the voices to go out of tune relative to each other.
BasementRiffs
Commerce
Quote from: kpatz on September 21, 2024, 01:43:52 AM
Thanks for the reply.  It is a brand new Take 5.  Turns out it just needed a calibration.  I didn't think this was the issue because I had played it A LOT in the shop and it sounded fine there.  So, I assumed I had triggered some hidden setting or something.  I guess the trip home from the shop threw off the calibration.   It's working fine now.
