Uploading patches from DAW
« on: September 16, 2024, 09:34:37 AM »
Completely new to a Prophet and love it so far! Is it possible to upload a patch created in a DAW to the Prophet?
Re: Uploading patches from DAW
« Reply #1 on: September 19, 2024, 08:02:36 PM »
Completely new to a Prophet and love it so far! Is it possible to upload a patch created in a DAW to the Prophet? Retro Bowl Unblocked
Yes, you can upload patches created in a DAW to the Prophet, but the process can vary depending on the specific Prophet model you have. Generally, you'll need to use a MIDI connection to transfer the patch data.
Qwave
« Reply #2 on: September 25, 2024, 12:45:18 AM »
What do you mean by "created in a DAW"?
Do you use an editor in your DAW? Or a plugin?
Only DAW plugins coded to work with the Prophet Rev. 4 will work with a Prophet Rev. 4.
keep on turning these knobs
558
« Reply #3 on: October 15, 2024, 01:40:07 AM »
Yes you can send a bunch of cc settings or even a whole sysex patch (program patch) to the synth out of your midi out from the daw.
Couple instances where it works for me, I keep pretty much constant midi routings in a template in my daw.  So when I play my prophet 10 everything gets recorded to the track in the daw which I have constantly routed to come out to the synth also.  There is no thru action so there is no loop.
So then when I move around in the daw with the cursor, I can change the sound of the synth to wherever in the recording it sounded.
I also send patches sometimes directly from an external patch 'library'.  Actually it's my Elgato stream deck using the sysex option of a midi plugin there to send a sysex block across the constant routing I created just for that purpose.  Easy to do if you are all set up with the routings constant.
Prophet 10, 0692
Ryzen 3900XT 12/24
Studio One
iPhone 5s Moog Model D via bluetooths of Reface Looper or Xkeys, Arturia Beatstep Pro w/Roland System 1m, Roland JP08, Roland TD17s as drums &->Prophet 10, Oxygen 8v2->Prophet, Akai Adv 25 or Launchey arps->Prophet10 or any all VSTs.
