Sequencer Stopping when switching patch
« on: September 13, 2024, 04:13:20 PM »
Hi there, on the Prophet 6 when you have a sequencer playing (let's say on patch 1) and you switch to patch 2, it will automatically play the sequence on patch 2. This is rad cause you can chain a bunch of patterns together.
The Take 5 on the other hand stops the sequence when you switch between patches... Is there a way to make it continue playing when switching like on the Prophet 6?
Re: Sequencer Stopping when switching patch
« Reply #1 on: September 19, 2024, 06:42:37 AM »
Hi there, on the Prophet 6 when you have a sequencer playing (let's say on patch 1) and you switch to patch 2, it will automatically play the sequence on patch 2. This is rad cause you can chain a bunch of patterns together. smash karts
As far as I know, there is currently no way to keep the sequencer on Take 5 playing as you switch between patches. This is a difference from Prophet 6, where the sequencer would automatically switch patches.
« Reply #2 on: September 30, 2024, 10:17:40 PM »
On the Take 5, the sequencer stops when you switch patches because it’s designed to reset when changing presets, unlike the Prophet 6, which allows continuous sequence playback across patch changes. Unfortunately, there’s no built-in setting on the Take 5 to allow the sequencer to continue running while switching patches like on the Prophet 6.
« Reply #3 on: October 03, 2024, 07:47:53 AM »
Never thought about that -- does the Prophet 6 experience any weirdness when doing this as patch parameters are reset? That's a neat feature.
I'd guess on the T5 you'd need to be careful with effects patches as that would likely cause problems when switching to a new patch/sequence.
