repeated factory presets?
Started by BeeRad, September 05, 2024, 07:37:39 PM
3 Replies 8,701 Views
BeeRad
Commerce
I have the new editor from Soundtower.  Trying to figure out how to use the librarian.  In my factory banks I have somehow found a few identical presets sprinkled throughout the factory banks.  How could this be?  I though factory banks could NOT be overwritten?  Is there a factory sysex file I could reload to return to the original presets?
gus
Administrator
Full Member
Hope the editor and synth are working well! The SoundTower Editor does allow you to write over the factory banks.
You can download the factory programs for the USER slots at the following link: https://oberheim.com/support/
From there, you can either transfer the User Programs to Factory from the Debug Menu (Transpose UP + DOWN + GLOBAL), or you can alternatively use the editor. In the ST Librarian, simply import the presets, then load them to the Factory slots on your synth.
BeeRad
Commerce
Many thanks.  I have the ST editor for my Rev2. Also.  Still have trouble really understanding the library section, even after watching videos.  W regard to the Teo 5 version, if I click on a preset to  audition in the banks section, it RENAMES (replaces) the preset.  Also the scrollbars for the two sections of the software appear to be reversed.  I.e. bottom scroll below banks scrolls the top interface section and vice versa.
gus
Administrator
Full Member
The librarian is confusing, no doubt. You can always reach out to Soundtower for questions/feature requests.
To import sounds, I usually hit Command + L. Select a category, name it whatever you want, then press 'Import' and load the Sysex file. Hit 'No' when it prompts you to categorize patches. From there, you can drag patches or use the arrow buttons in batches of 16 to transfer to the Factory Banks.
