prophet 6 disconnects audio from logic 11.0.1
« on: August 21, 2024, 12:46:54 AM »
Hi. I just got a prophet 6 desktop with firmware 1.7.8 . I use it with Logic x 11.0.1.
If I open the daw logic pro x and then turn on the prophet everything works regularly, it is seen inside logic and I can control it via midi via an external keyboard (I use a novation bass station 2). The prophet is connected with a midi cable directly from the keyboard and also with a usb cable to the computer.
If I close the logic project and reopen it or open another project while the prophet is on it does not work anymore, I no longer get the prophet audio on the external instrument track of Logic.
I am forced to turn it off and on again to make it work. If I do this, it works again. Has anyone had a similar problem? I attach a link with a video to understand better. Thanks for the help
https://youtube.com/shorts/uiVUMrPM6c8?si=8Wxn-w74QHpAco2k
Re: prophet 6 disconnects audio from logic 11.0.1
« Reply #1 on: November 11, 2024, 08:50:24 AM »
It sounds like a MIDI connection or software recognition issue in Logic. Try reassigning the Prophet 6 in Logic’s MIDI settings after reopening projects or updating firmware/drivers. MIDI resets can sometimes help resolve recognition issues without restarting.
gus
  • 174
« Reply #2 on: November 11, 2024, 10:00:38 AM »
I would also try setting param xmit/rcv to OFF on the Prophet as a test, in the off chance it is getting errant param data from Logic or from another synth.
Sequential | Oberheim
« Reply #3 on: November 25, 2024, 08:30:37 AM »
Look at the midi reset messages in Logic Pro. These caused me an issue for my P6, OB6 and T6 when I upgraded to 11. Turning off the reset messages for hardware fixed this issue.
Waldorf Iridium. Prophet X. Prophet 12 Module. Prophet 6 Module. Ob-6 Module. Trigon-6 Module. Eventide H9000R (x2). Tegeler Audio Schwerkraftmaschine / Raumzeitmaschine / Creme RC (x3). Bettermaker Mastering Limiter, Mastering EQ, Mastering Compressor. Bettermaker VSPE. Avid S3.
Mac Studio. Logic.
« Reply #4 on: March 06, 2025, 01:58:57 AM »
thanks so much! I noticed, it's in SETINGS - MIDI - RESET the command Controller 4 Foot pedal. That has to be turned off.
« Reply #5 on: March 20, 2025, 02:09:58 AM »
THANK YOU very much for this great advice!
The MIDI Reset Controller 4 Foot Pedal was also the issue for me with my OB-6 module.
The OB-6 could only be used again after a restart.
Now everything is working perfectly again!
