Hi. I just got a prophet 6 desktop with firmware 1.7.8 . I use it with Logic x 11.0.1.
If I open the daw logic pro x and then turn on the prophet everything works regularly, it is seen inside logic and I can control it via midi via an external keyboard (I use a novation bass station 2). The prophet is connected with a midi cable directly from the keyboard and also with a usb cable to the computer.
If I close the logic project and reopen it or open another project while the prophet is on it does not work anymore, I no longer get the prophet audio on the external instrument track of Logic.
I am forced to turn it off and on again to make it work. If I do this, it works again. Has anyone had a similar problem? I attach a link with a video to understand better. Thanks for the help
https://youtube.com/shorts/uiVUMrPM6c8?si=8Wxn-w74QHpAco2k
