Any wishlist for 1.1.3?
« on: August 04, 2024, 02:38:37 PM »
It’s a lot of time since the last update. That’s my suggestion for a 1.1.3:
-Dual layer split zone (one oscillator x zone)
-Resonance compensation
-Unison detune
-More features for the sequencer
What’s yours?
Re: Any wishlist for 1.1.3?
« Reply #1 on: August 05, 2024, 04:12:56 AM »
Don’t you just use the vintage knob for unison detune?
« Reply #2 on: August 07, 2024, 07:07:24 AM »
yes, It'd be nice to have a bit of control on the number of tones though..
To say the truth, I wish they linked some sort of parameter morphing to some knob (as the Moog Muse does): I'd just suggest the Vintage one itself for example..
« Last Edit: August 07, 2024, 07:11:17 AM by Rudy Nicoletti »
« Reply #3 on: August 07, 2024, 10:42:25 AM »
Number of tones? Do you mean the number of parameters or the number of voices?
There are several parameters mapped to the vintage knob, including tuning, filter frequency and envelope timing stages.
If you mean the number of voices, hold down the “unison” button and use the +/- keys to set the number.
« Reply #4 on: August 10, 2024, 12:19:00 PM »
Hi pass filter FX modulated by simple A/D envelope or macros in the FX section, expanded FM range in polymod.
OB6 desktop x2, DSI Rev2 16, Toraiz AS-1, Prophet 12, Pro 2, Vermona 14, Roland System 8, Matrixbrute, Jomox Sunsyn MKII
Scott McAuley
  • 2
  • www.orano.co.uk/shop
    • Scott McAuley Sounds
« Reply #5 on: August 26, 2024, 01:51:45 PM »
 - Larger Range for PolyMod FM,
 - It's great we can modulate the OSC3 LFO Rate with Main LFO, but the range is way too small, Larger FM range would resolve this too.
 - Being able to send OSC3 LFO to Main LFO Rate Via Polymod would be great too, even by Holding the Polymod Filter button so it flashed to let us know OSC3 LFO or Filter Envelope is being sent to Main LFO Rate.
Sound Matters!
« Reply #6 on: August 30, 2024, 10:11:46 AM »
An NRPN to enable modulation of the output level of the white noise generator. (Unless it's possible but not documented? Or maybe it's just not possible!)
/edit - oh, and more reverb options, natch.
« Last Edit: August 30, 2024, 10:20:44 AM by NickMilner »
« Reply #7 on: September 15, 2024, 08:13:07 AM »
I'd like something to "smooth out" the negative Feedback/Drive range - seems like it just goes from 0 to 100 crazy at one point in the range.  Maybe I don't understand it enough, but I'd like it to go crazy a little less suddenly, make more use of the range in between.
« Reply #8 on: September 26, 2024, 01:26:27 AM »
Agree
« Reply #9 on: October 14, 2024, 11:53:32 AM »
With the Trigon, I miss the option of opening and closing the filter with the mod wheel. It looks like this is only possible with aftertouch (I'm used to it the other way round: aftertouch: vibrato, mod wheel: cutoff).
I don't know if this is possible via firmware update, but it's holding me back a bit from buying it at the moment.
« Reply #10 on: October 14, 2024, 02:11:38 PM »
Or just buy a little MIDI translator box and convert CC2 to CC74 and feed the translated CC back into the synth.
« Reply #11 on: October 15, 2024, 11:46:39 AM »
Thanks for your reply!
Do you have a recommendation for such a MIDI tool box? I don't have any experience in this way.
BT
  • 124
« Reply #12 on: October 15, 2024, 11:58:31 AM »
« Reply #14 on: October 15, 2024, 01:42:03 PM »
If you're feeling adventurous, I can definitely recommend one of these...!
https://www.youtube.com/watch?v=bnpOO8NQMsY
« Reply #15 on: November 29, 2024, 05:50:53 AM »
The option in the PolyMod section to have the Filter Env control the OSC 3 amount. That is, being able to have swells of FM, or snappy spikes of FM.
« Reply #16 on: January 19, 2025, 02:55:55 AM »
Reassign AT section modulation to target with expression pedal, mod wheel or even pitch wheel.
- or a mix of these
- this would create more headroom for modulations, I think
AT is pretty useless, unless for a very few things, since I contemplate Trigon Desktop with no AT keyboard
- AT is not so precise to control modulation anyway
So a simple value to assign expression pedal, mod wheel, pitch wheel or AT as source to AT modulation section
- would give me enough headroom to get a Trigon
The LFE expander is quite an extra cost to do these things, I could just go for Muse directly instead.
KG
« Reply #17 on: May 30, 2025, 07:36:11 AM »
I really would like to have information about value of a knob that is being adjusted.  Such thing I have on for example my Roland Fantom EX, when you start turning knob (no matter if volume or cutoff) there is pop up information on LCD about value of a knob, and when you stop turning knob it is being hidden after second or two.
How would it work for Trigon-6:
1. On a "Bank Program" display you normally see chosen patch number.
2. When you start adjusting a knob this number shows current value of a knob (for example some of them have range from 0-127)
3. When you stop changing value of a knob after a second is shown again.
Such a values of knobs are showed for example also in soundtower plugin/editor.
KG
« Reply #18 on: June 13, 2025, 02:11:44 AM »
After using Trigon-6 a while I would propose in general:
- Using mod wheel to control all modulation targets from aftertouch section
  Both option works for me - using mod wheel instead of aftertouch, or in connection with aftertouch.
- Also if there was a way to control LFO frequency instead of LFO amount would be great (I know that I can target OSC3 and use it as LFO but then Polymod section does not have AMP as a modulation target...).
- Larger range for Polymod section please!
« Reply #19 on: July 17, 2025, 08:00:59 AM »
Include Midi 'Start/Stop' for the sequencer... like the Take 5.
