Calibration failure after 2.0 update
Started by mattling, July 10, 2024, 11:45:36 AM
34 Replies 29,159 Views
scottr
Commerce
I had numerous full calibration failures, what I ended up doing by the direction of Sequential was to revert back to V1.1.1.0 then install V2.0 and immediately run full calibration.  I didn't power cycle it just ran one after the other and it installed, full calibration went fine and is working.  Saying this, I am hopeful they come up with a bug fix because in my mind I continue to wonder if this is a shortcut or permanent.
nanostepper
Commerce
Hi everyone,
Same issue for me on the OBX8 Desktop - I updated to 2.0, calibration failed on the SEM voice. I reinstalled 1.1.1.0 and all is fine again.
Matthias Adloff
Commerce
#22
Same issue here. Since I just received my brand new OB-X8, I unfortunately don't have any other old FW files. Is there any place to download the v1.1.1.0 to give that rollback method a try?
-> EDIT: Found it, just right in this thread :) Sorry. So now let's see if that works.
Terryh@56
Commerce
I had similar issues. Installed 2.0, followed instructions and calibration will not work. Stuck on Voice 1.
Did Calibration again. Went fine. Tested tune button and everything worked
The next day started, let warm up and tuning is stuck on voice 1 again, just like before.
gus
Administrator
Full Member
It's looking like we have resolved this issue in software and we will release an update in the very near future.
For anyone who has had trouble calibrating on OS 2.0, we have a simple workaround. In addition to the normal OS update steps, you must turn the master volume to max before running full calibration. The steps are as follows:
1. Update the OS to 2.0 https://oberheim.com/support/
2. Power the unit off, then on
3. Reset Globals
4. Clear calibration
5. Turn the master volume to max
6. Run full calibration
Here are the steps in more detail, which are also listed in the ReadMe and on our website.
RESETTING THE GLOBAL PARAMETERS
You must reset the Global parameters of the OB-X8 after you update the OS.
   •   Press the Global button.
   •   Use the Scroll Knob to select Reset Globals, then press the Write button.
CLEAR CALIBRATION
You must clear calibration after you update the OS.
   •   Hold Transpose Up + Down and press the Global button.
   •   Select the first option to Clear Calibration and press Write.
   •   From here, turn the master volume to max and run full calibration following the steps below.
RUN FULL CALIBRATION
Please run the full calibration Global option after you update the OS.
   •   Turn master volume to MAX.
   •   Use the Scroll knob to select Full Calibration, then press the Write button.
   •   The synthesizer performs its auto-calibration procedure. Do not turn off the power while it is doing this.
   •   When finished, the front panel controls return to normal, and you can play the OB-X8 again.
agavephoto
Commerce
Excellent! This solved my OS 2.0 installation problme as I was always stuck with no progress on the full calibration after the install. I had been using headphones before/after and the master volume was always at a very low setting.
Quote from: gus on August 22, 2024, 09:59:56 AM
3. Reset Globals
CLEAR CALIBRATION
gus
Administrator
Full Member
OS 2.0.0.1 is released, which contains a fix for users experiencing calibration issues after updating to 2.0.
Please reset globals, clear calibration, and run full calibration after successfully updating to 2.0.0.1. These steps are outlined on our website, in the ReadMe, and in the pinned OS post on this subforum.
If anyone continues to have issues with calibration, please reach out to support@oberheim.com and we will help you out!
Matthias Adloff
Commerce
Quote from: gus on August 23, 2024, 04:17:56 PM
Yes. This works flawlessly. Thank you for the relatively quick help.
Benskia
Commerce
Hi everyone,
Just wanted to say thanks to this forum and the advice given on this thread.
I did the update fine and all the global resetting etc was fine. But just recently I struggled to get the tune function to get past voice 1.
The workaround with the master volume setting sorted it out.
Nice!
Matthias Adloff
Commerce
Quote from: Benskia on September 03, 2024, 11:11:58 AM
Hi everyone,
Nice!
Do I get this right, the calibration failed on using OS 2.0.0.1 and not OS 2.0? This is different from my experience.
Benskia
Commerce
Quote from: Matthias Adloff on September 03, 2024, 02:15:39 PM
Hi everyone,
Nice!
Hi. Nope - I was just on 2.0. I haven't gone the extra stage further yet and gone onto 2.0.0.1
Beaubourg
Commerce
I had the calibration problem with 2.0. Last night I finally got around to installing 2.0.0.1. It worked great, no problem whatsoever. Thank you very much.
raynoran85
Commerce
Quote from: The Real MC on July 31, 2024, 10:42:17 PM
uno online
v2.0.0.0 upgrade successful, no problems
I can't wait to get out of work to run home and try this, I was about to parts out my Phantom Professional.  I hope this works. Thank you so much
ckettering
Commerce
Just purchased a new keyboard. It was on version 1.0.0.3 and updated to 2.0.0.1. Having the voice calibration problems with the OB-X voices. Tried the clear CAL and Global reset. That works. But then later after having it off for a while it wouldnt calibrate again.
Quatschmacher
Full Member
Quote from: ckettering on September 27, 2024, 07:07:04 AM
Did you follow the pinned troubleshooting guide? They advise turning output volume to maximum during calibration to overcome the issue until a software fix is implemented.
