Global settings save issue
« on: July 07, 2024, 05:41:13 AM »
Hello,
I would like to share that when I set midi parameters send and receive settings to cc rather than nrpn in the global settings, it never saves on power down and I always have to set it up before each use. Could I please request this saving once changed?
Thank you
gus
  • 172
Re: Global settings save issue
« Reply #1 on: July 09, 2024, 08:20:55 AM »
Hi Sammimiami,
Not seeing this behavior here. Are you exiting Globals after making the change? Everything gets saved on exit, so that may be the missing piece here. If not, let us know or contact support@oberheim.com and we can dig in further.
« Reply #2 on: July 15, 2024, 01:02:48 AM »
Thanks - I am exiting globals after changing. I'll email now! Thank you.
« Reply #3 on: July 26, 2024, 12:44:21 AM »
Seems like a bug related to alternate tunings... still under investigation!
gus
  • 172
« Reply #4 on: July 29, 2024, 09:59:43 AM »
Yes, the param send/receive global fields appear to not get saved if an alternate tuning is selected. It's on our list and on the software team's radar and will be addressed in a forthcoming update. Apologies for any inconvenience with this one!
« Reply #5 on: November 23, 2024, 02:28:21 AM »
I have an issue... when I make sure my globals are all set to per preset... whenever I load the sound tower editor vst... the per preset settings all go to global,,,, it's very strange...
help?
« Reply #6 on: November 23, 2024, 08:37:45 AM »
help?
If you leave the MIDI and/or USB cables unplugged then load the editor, does the same thing happen?
