2.0 not responding to NRPNs
« on: July 05, 2024, 02:21:44 AM »
Since updating the synth to 2.0 it won't respond to NRPNs.  On either DIN or USB.  I've done a Globals reset and the synth is set to send and receive NRPNs.  I can configure it to work with CCs but not NRPNs.  Have I missed an extra setting or reset that needs doing or is this a bug?
Re: 2.0 not responding to NRPNs
« Reply #1 on: July 05, 2024, 06:27:35 AM »
I think I’ve figured it out!  Pre 2.0, the synth would receive both NRPNs AND CCs even with its receive setting at NRPNs.  This was always a bit strange but I took advantage of it by sending CCs to the synth for modulations as they use up less midi bandwidth, only for the parameters of course which CAN receive CCs, some NEED NRPNs.  So the LFE was clever and used NRPNs when it needed to but otherwise used CCs to minimise bandwidth.  With 2.0 they’ve changed it so when set to NRPNs, it ONLY receives NRPNs, not CCs.  So I’ve now changed the table that tells the LFE whether to send an NRPN or CC for each parameter and then now all use CCs.  Easy fix - sorry for the false alarm but I don't seem able to edit the original post.
« Reply #2 on: July 07, 2024, 05:34:07 AM »
I'm having issues with sending nrpns from cirklon to obx8... I've never actually been able to do it and not sure why. On cirklon, I set msb to 0 and lsb to the nrpn in the obx8 manual (it's for a nrpn less than 127, hence msb bei g 0), but it doesn't do anything when changing the value being sent.
Receive Nrpn set in obx8 globals. If anyone has any suggestion I'm interested to hear!
« Reply #3 on: July 07, 2024, 07:17:10 PM »
On further investigation, it seems that cirklons nrpn support is not yet fully developed...
« Reply #4 on: September 21, 2025, 02:16:29 AM »
Further update. I think obx-8 requires 14 bit nrpn messages but cirklon only sends 7?
