Is there a way to trigger Tune via Midi message?
« on: June 19, 2024, 06:56:35 AM »
Is there a way to trigger Tune via MIDI message?
Re: Is there a way to trigger Tune via Midi message?
« Reply #1 on: June 27, 2024, 12:38:02 AM »
Yes, there is a way to trigger Tune via MIDI message. The method to do so can vary depending on the equipment and software you're using. For example, in some cases, you might need to activate certain settings in the software to respond to MIDI messages for tuning purposes
« Reply #2 on: June 27, 2024, 03:33:53 AM »
More bot replies? Bloody hell.
As far as I can tell there is no MIDI command that activates the TUNE button function remotely.
Qwave
« Reply #3 on: June 29, 2024, 03:07:50 AM »
In the MIDI specs there is the Tune Request defined in the System Common Messages.
Simply send this hex value: F6.
But I don't know, if this was implemented. It is not in the Prophet Rev. 4 MIDI implementation PDF of late October 2020
keep on turning these knobs
« Reply #4 on: June 30, 2024, 10:15:43 AM »
I tried to send 0xF6 to the Prophet-10, but it didn't start tuning.
g3o2
  • 169
« Reply #5 on: June 30, 2024, 05:32:15 PM »
Maybe there is a purpose behind the non-implementation of this MIDI message. Maybe Prophet should not be tuned too often ;-)
