MIDI SYNC
Started by cance, October 14, 2016, 01:24:15 AM
15 Replies 26,969 Views
cance
Commerce
HI Guys i'm new user, i'm in love with my tempest, but i found difficult to have a good  sync with ablteon live.
do you have any good councils for me?
tnx in advance
soidthezoid
Commerce
Quote from: cance on October 14, 2016, 01:24:15 AM
tnx in advance
I've had the same problem with Ableton Live 9.6.1.  Set your Tempest to Master & Ableton to Slave, you will have better sync.  You will also need to adjust the MIDI clock delay on the Tempest Midi Input port in the MIDI section of Ableton's Preferences (MIDI section).  I have mine set at -80 ms, but you can adjust it differently if necessary, usually a negative number.
Yorgos Arabatzis
Moderator
Full Member
#2
Watch my tutorial ;)
https://youtu.be/2seraaKagYk
Also if you're able try Ableton Link feature...Below it's a quote of mine in tips & tricks thread..
"To anyone searching for a tight sync between Ableton Live & Tempest if you own an iOS device with the free Midi Link Sync app and this adapter http://www.apple.com/shop/product/MK0W2AM/A/lightning-to-usb-3-camera-adapter
you can have a very tight sync using Ableton's Link feature  ;)"
If you go down the midi road set Tempest to be the slave and Live to be the master..
cance
Commerce
HI GUYS i found that -30 ms in the MIDI clock preference is my way to have a good sync..
TNX SO MUCH.. :)
Yorgos Arabatzis
Moderator
Full Member
Glad we helped :D
Quote from: cance on October 14, 2016, 03:37:16 AM
TNX SO MUCH.. :)
soidthezoid
Commerce
TNX SO MUCH.. :)
No worries :)
soidthezoid
Commerce
Quote from: Yorgos Arabatzis on October 14, 2016, 02:38:57 AM
If like me your MIDI / AUdio interface is combined, (Scarlett 18i20) you will need an additional IOS compatible midi interface to attach to the iPad & connect to the Tempest, am I right?
soidthezoid
Commerce
Quote from: soidthezoid on October 21, 2016, 08:49:00 AM
By the way, which MIDI interface did u attach to iPad in order to get the solid sync with Tempest?   I'll bet some work, some don't!
Yorgos Arabatzis
Moderator
Full Member
#8
Basically i've hooked Tempest to my iPhone via the adapter i've posted and with the Midi Link Sync app it's like i've installed a wifi synchronizer into Tempest  :D...No midi stuff going on there ;) Just syncing in the air using an ad-hoc connection between iPhone and a MacBook Pro and it's damn tight!I just love geeky stuff 8)
Quote from: soidthezoid on October 21, 2016, 01:49:35 PM
soidthezoid
Commerce
Quote from: Yorgos Arabatzis on October 21, 2016, 05:56:28 PM
Ah ok, u mean the Tempest is connected directly to the iPhone via the lightening to USB (Camera) adapter?  Strange, when I tried that the Midi Link Sync app didn't list the Tempest as one of its MIDI destinrations.  Am I missing something?  Any chance you could list some detailed steps for setting the thing up please?  Obviously Tempest is set to sync slave via USB, right?  Which version of IOS did you use at the time?
Yorgos Arabatzis
Moderator
Full Member
#10
Quote from: soidthezoid on October 23, 2016, 03:48:58 PM
Exactly!
This should not be happening check your cables and look at the bottom of the Midi>>Link menu and you'll see Tempest.Tick it and then press "enable sync".
Quote from: soidthezoid on October 23, 2016, 03:48:58 PMWhich version of IOS did you use at the time?
I'm on a jailbroken OS 9.3.3
Quote from: soidthezoid on October 23, 2016, 03:48:58 PMObviously Tempest is set to sync slave via USB, right?
Nop...Tempest (Master) sending sync via USB -> Midi Link sending sync via Wifi -> Ableton Live (Link Enabled)
soidthezoid
Commerce
Quote from: Yorgos Arabatzis on October 24, 2016, 02:57:38 PM
Exactly!
Sweet, I'll give that a go ASAP, cheers :)
soidthezoid
Commerce
Quote from: soidthezoid on October 25, 2016, 03:08:46 AM
Exactly!
Great, it's working, thanks!  Was just a dodgy lightening to USB adaptor, it seems!  Cheers again ;)
Yorgos Arabatzis
Moderator
Full Member
And one last thing...
Below the enable sync on the Midi Link Sync app there's a slider where you can adjust exactly the timing between Tempest and Ableton Live..I set mine a little bit to the left ;)
soidthezoid
Commerce
Quote from: Yorgos Arabatzis on October 26, 2016, 03:37:54 AM
Ah yes!  I forgot about that!  I was planning to tackle that problem some other way but that's a much better solution!  Cheers mate ;)
bobbyquine
Commerce
Expert Sleepers USAMO is a good solution too. Link to midi works well though....
