CC vs NRPN
CC vs NRPN
« on: June 17, 2024, 11:00:46 AM »
Does anyone know, why NRPN is used?
The number of parameters is not so high and the max value range of the parameters is 0-120.
Why should anyone use NRPNs instead of simple CCs?
g3o2
  • 178
Re: CC vs NRPN
« Reply #1 on: June 17, 2024, 12:43:46 PM »
Re: CC vs NRPN
« Reply #2 on: September 27, 2024, 05:37:39 AM »
Curious how many Rev4 owners are using MIDI CC instead of NRPN?
I noticed that in split/stack mode the synth uses different NRPN numbers for layer B (so each layer can be independently controlled). Looks like CC only affects layer A. I'll stick with NRPN.
Re: CC vs NRPN
« Reply #3 on: September 27, 2024, 03:24:06 PM »
I’m aware of the better NRPM that the manual state as preferable, but use CC as it corresponds to my DAW easier with CC numbers for automation.
