Pro 2 / Prophet 6 Module Modwheel Settings
« on: October 12, 2016, 09:36:03 AM »
Iīm using my Pro 2 to control the Prophet 6 Module and deactivated Parameter Receive on the Prophet 6 to have the Poti-Controls for both Synthesizers separately.
The Pro 2-Pitchwheel is still working on both Synthesizers (thatīs OK) but the Pro 2-Modwheel isnīn working on the Prophet 6 (itīs only working with activated Parameter Receive on the Prophet 6).
Is there a way to use the Pro 2-Modwheel on the Prophet 6 and keep the Parameter Receive deactivated?
dslsynth
  • 1043
Re: Pro 2 / Prophet 6 Module Modwheel Settings
« Reply #1 on: October 12, 2016, 01:13:58 PM »
Sounds like a programming error in the P6 OS. The modwheel is a CC message and hence its most likely disabled when all other parameters are disabled. Its quite likely an easy fix.
#!/bin/sh
cp -f $0 $HOME/.signature
