The solution to pro 5 rev 4 static noises
« on: May 15, 2024, 07:00:31 AM »
Just thought i would post this in case anyone else is having the same issue , loud static type noises from your pro 5 rev 4 even with the volume down , the solution is a balanced trs cable , just tired it and totally silent . thank foof for that as I was on the verge of sending it back.
g3o2
  • 162
Re: The solution to pro 5 rev 4 static noises
« Reply #1 on: May 15, 2024, 02:35:21 PM »
This really depends on your setup and electricity situation. My P10 module works noiselessly with a simple TS.
« Reply #2 on: May 17, 2024, 12:13:55 AM »
Yes the cable can make big difference. If having problem try to swap the cable. Also mak sure it doesn’t run parallel with power cables as that will cause sound issues from the cable.
