Key commands
Key commands
« on: May 13, 2024, 08:18:29 AM »
Have not seen this in the manual:
- While holding down Global and selet Program 5 (the global option buttons) there is an option that says 000 and can be set to + or - values. What is that?
- When then hit one more time it says Jup, what is that?
« Last Edit: May 13, 2024, 09:49:58 AM by Analog Prophet »
Re: Key commands
« Reply #1 on: May 21, 2024, 01:57:10 AM »
My guess is the Velocity Response Curve. Check the light to see what globals mode you'r in.
Best,
Arjan
Re: Key commands
« Reply #2 on: May 23, 2024, 02:03:05 PM »
This isnt Global 1 or 2 but another mode while holding down Global and anlther key, for instanser Global + 1 show the Firmware version. My question is in this mode but Global + 5.
gus
  • 249
Re: Key commands
« Reply #3 on: May 24, 2024, 10:19:45 AM »
Global + 5 is for CV calibration - more details on Page 54 of the manual. It gets cal'd from the factory, so you generally shouldn't have to adjust these settings.
Enter cv cal mode   "Hold Global + 5
2) Prog 1 = CV out lo; 2 = CV out high; 3=CV in lo; 4= CV in high . Inc/Dec to change value
3) Hitting 5 does cv in auto cal
4) Hitting 8 exits cal mode, at any time"
Re: Key commands
« Reply #4 on: May 25, 2024, 01:45:49 PM »
Thank you very much for clearing this out!
