Poly After Touch and OB-X8
« on: April 12, 2024, 01:19:03 AM »
Bought an Korg Keystage 61 (but returned as MIDI 2.0 didn’t worked out at expected and the keys were not good) that has a Poly Aftertouch and MPE keyboard. OB-X8 receive external Poly Aftertouch and it worked out at once without any problems.
I thought I would use Poly AT for everything, but it wasn’t the case - it works for some few sounds but not the majority of sounds I use.
The next MIDI controller I will buy will be with Poly AT (still there are only some few around but I’m sure it will be more common for new models) as the OX-X8 receives Poly AT. If Poly AT can be set per patch at the controller it would make everything smoother.
the8bitdeity
  • 48
  • Ham handed synth enthusiast
Re: Poly After Touch and OB-X8
« Reply #1 on: April 13, 2024, 09:09:59 AM »
In general all of the aftertouch implementations on Sequential synths have a generic "Aftertouch" amount and it will use Channel or Poly based on what the controlling keyboard sends. That's just kind of how they've done it for a long time and I don't expect it to change. Probably easier to change what type of AT your controller is sending.
Kijimi, Xerxes mk2, OB6D, P6D, Prophet 5D (expanded), OB-X8D, Hydrasynth, Pro 3, Wavestate, MS20D, A4mk2, ARmk2, MC202, Avalon, Syntakt, Octatrack, NLDR, H9000, Digitone, Deckard's Dream mk2, Isi-Nin, Roland System 500 + other Eurorack
« Reply #2 on: April 14, 2024, 01:41:02 PM »
I have a vintage Ensoniq SQ-80 with PolyAftertouch and have tried it playing my OB-X8. It works as a polyphonic Aftertouch for the filter (controlling each voice's filter independently) but for controlling the modulation it acts as a channel Aftertouch.
g3o2
  • 179
« Reply #3 on: April 16, 2024, 03:17:02 PM »
That’s because on the OBX8 and the Prophet rev 4, the LFO is not polyphonic, aka per voice. Then again, controlling LFO with polyAT is kind of missing the point. In a polyAT setting, you want your fingers to become the LFO or the envelope rather than to control an LFO or an envelope.
« Reply #4 on: June 25, 2024, 04:48:26 AM »
I can also confirm:
-obx8's own keyboard does channel aftertouch only, which makes aftertouch for lever box lfo amount possible.
-obx8 keyboard does not support poly pressure and can't modulate the filter using aftertouch.
-obx8 will respond to external midi keyboard poly pressure for modulating filter for individual voices.
-obx8 will respond to channel aftertouch from external keyboard to modulate lever box lfo amount.
« Reply #5 on: June 25, 2024, 07:24:36 PM »
OBX8 keyboard does modulate filter cutoff (all voices) using its channel aftertouch.  Check your page 2 menu, there's a setting to vary the amount of filter aftertouch and it may not be turned up.
And filter cutoff (all voices), see above.
« Reply #6 on: June 26, 2024, 01:03:45 AM »
Thanks Real MC. You are right! That good old page 2.
I am most happy to get poly pressure working as I never realized it was possible based on what people were saying online..
