There always seems to be some amount of overdrive affecting the sound, even when all drive/distortion parameters are at zero (including Ext Audio level and input gain which seem to add drive when no ext audio source is plugged in -same as a Minimoog).
Pro3 doesn't seem to be able to do buttery smooth filter sounds as well as the little Dreadbox Typhon for example (no fx used).
This seems to be a quality of the filter stage of the Pro3, regardless of which filter type is used.
Anyone else notice this?
Setting OSc levels all to 50% helps but still there's some drive happening it seems
