Aftertouch problem?
Aftertouch problem?
« on: March 08, 2024, 10:42:51 AM »
Hi everyone. I've sent a message to Oberheim/Sequential about a major issue with my OB-X8.
Has anyone else noticed the same thing on their OB-X8 keyboard? From a basic patch, when I light up the OSC1 knob in the Levers section, to get a vibrato effect, and I want to use the Aftertouch to control it by lighting up the TOUCH knob to the Mod position, I get varying pitch modulation by pressing down on a key.
But when I go in the PAGE 2 setting and adjust Aftertouch Amount, it makes no difference. Even if I put the amount to 0 there is still the full amount of modulation from the aftertouch.
It does work correctly for the Filter though.
I'm currently waiting for a reply from them on this. Maybe I got a defective unit? Or it may be a software bug?
Re: Aftertouch problem?
« Reply #1 on: March 08, 2024, 12:09:57 PM »
Doesn’t aftertouch control only the other LFO? i.e. the one on the main panel and not the one in the bender box?
« Reply #2 on: March 08, 2024, 04:20:29 PM »
No. It controls the modulation level much like the left lever in the Levers section. And it works, but always to the maximum.
« Reply #3 on: March 10, 2024, 05:52:10 PM »
My unit does that too.  Same behavior controlling the OB-X8 from an external MIDI controller.
I get around it by varying the aftertouch sensitivity on the external MIDI controller.
« Reply #4 on: March 14, 2024, 10:22:23 PM »
As I stated in another thread, someone named Sally from Oberheim Support has confirmed that the issue with aftertouch controlling the modulation incorrectly is a software bug. The programming team at Sequential/Oberheim is aware of it and trying to correct it in an upcoming firmware update. No release date estimate was given though.
SMV
« Reply #5 on: March 19, 2024, 08:07:36 AM »
I posted this problem om this forum the 16 of June 2023, but apart of a strange reply, nobody took care about it ;)
SMV
« Reply #6 on: March 19, 2024, 11:57:18 AM »
Did you email sequential support about it though? That’s the only guaranteed way to get it looked into as the Sequential staff don’t read every single post on here.
SMV
« Reply #7 on: March 20, 2024, 02:53:25 AM »
I know it. I was just pointing out that i found this issue many months ago and i wrote it on this forum, to see if someone had the same issue. But strangely nobody in the forum, cared about it
SMV
« Reply #8 on: April 14, 2024, 01:49:25 PM »
PROBLEM SOLVED
The Aftertouch software bug seems to have corrected itself!
A reminder of the initial problem I was having: Controlling the modulation from the Aftertouch was not smooth and the maximum amount of it did not work when setting the Aftertouch Amount setting in page 2.
After I played my OB-X8 from another MIDI keyboard with Aftertouch and using it, it now works as expected and much more smoothly from the OB-X8's own keyboard. And the maximum amount of it can be controlled from the Page 2 Aftertouch Amount correctly now.
I don't know why the OB-X8 needed to receive external MIDI Aftertouch messages in order to correct itself, but I'm glad it did.  ;D
Just thought I'd let everyone know.
« Last Edit: April 14, 2024, 01:53:31 PM by AlainHubert »
« Reply #9 on: April 17, 2024, 06:11:58 PM »
I thought it was solved but alas it has returned today…
