Hello,
Apologies if this is in the wrong section, I didn’t see a dedicated section for the Pro One.
I’m trying to trigger my Pro One via the Kenton Pro Solo. I’ve read that it should trigger out if the box, and so reset to the factory settings (I bought the Kenton used) to make sure setting were correct.
The Kenton is receiving a midi signal from my midi keyboard (it lights when played), but there is no sound. However, there is sound when I play the Pro One keys, which means the issue is either something to do with the Kenton/settings or the Pro One input set up or triggers.
I have 3 mono cables running from kenton to Pro One for gate, cv and filter.
I appreciate any help! Thanks
