Thanks for your reply! That now makes sense after doing some more reading about each of the individual voice cards in the prophet, and the functions of each. So I found the following Boomstar SEM Filter Module: https://www.purelocal.com.au/products/studio-electronics-boomstar-modular-sem-eurorack-filter-australia
I understand that if compatible this filter would only effect the overall audio, would it do it in Mono?
Also would the place to plug this filter into the Prophet be the pedal input?
This module only allows for mono input and mono output, yes - most do. And no, you don't plug the filter into any pedal input. You have to plug the Prophet output into the filter input and connect the latter's output to your mixer or audio interface. In other words: There's no way around mono in this case.
And yes, the outboard filter would only affect the overall audio signal that comes out of the Prophet. There's not really any alternative.
You should also consider that the Prophet-6 is not really made for modular integration. It lacks CV in and out connectivity, so you can't make it interact with a modular system. You can only use modules as audio processing tools. For what you would like to do six of those SEM filters had to be part of the individual voice boards.
I see you have got a Pro 2, have you been happy with that synth? When researching the Prophet/OB-6 I found plenty of people were recommending it as an alternative with its 4 voice paraphonic mode.
Oh yeah, I'm very happy with the Pro 2. However, I wouldn't say that it could be a supplement for the Prophet-6. Those two are totally different synths.
First of all, the Pro 2 is for tweakers and those who want do dig really deep into sound design with its excessive modulation options. The Pro 2 is not really a modular synth, as there are of course still a couple of hard-wired connections in there, but it gets you as close to a modular system as a self-contained unit can. Compared to what it actually offers, the Prophet-6 is sonically a very flexible synth, but nowhere as deep as the Pro 2.
Then you might consider that the Pro 2 is a hybrid synth, i.e. it has digital oscillators, a digital character section, and digital delays.
Thirdly, there's a huge difference between polyphony and paraphony: In a polyphonic synth, each voice is articulated individually, from the oscillators via the filters to the VCA. In a paraphonic synth, the settings in the signal path that lie beyond the oscillators are shared amongst all oscillators. (Here it shows why it's important to differentiate between an oscillator and a voice. While an oscillator is part of a voice, a voice is made of everything that's implemented in the full signal path. In that sense, you can of course play different oscillators on a paraphonic synth, but only with a single-voice or monophonic articulation.)
However, in the paraphonic mode of the Pro 2, the four oscillators can be triggered independently, each with its own envelope. But the two filters are still shared by the all oscillators, which means - in case you're making use of the filter envelope - that the filter envelope won't be retriggered once a key is already held. There are a couple of ways to work around that a bit with the DC offset parameter, but strictly speaking a fully articulated filter behaviour
per voice can't be achieved because the Pro 2 is a monophonic synth in the first place.
If pads are important to you, this is something you should consider amongst the question about whether 4 paraphonic voices would be enough.
If you don't care too much about full polyphonic articulation, you can of course also misuse the paraphonic mode of the Pro 2 by selecting 4 totally different oscillators, which is what Marc Doty describes as "articulated polyphony." I would rather use the term "quartet mode," since it enables you to play a chord with up to 4 different waveforms, which one could almost compare to 4 different instruments within an ensemble.
Sorry for the long post, but I hope it helps you in some way.
