My bad, I should have checked that particular interface.
- I've only had combined XLR with center having a 1/4" as well in all gear
Babyface Pro has two independent 1/4" inputs for instruments as well, on the side.
https://rme-audio.com/babyface-pro-fs.htmlYou need as you said in original post with TRS(tip, ring sleeve) or TS in one end and XLR other.
I cannot reach your link without entering a lot of stuff to show I am not a robot.
- so cannot confirm that choice
REV2 out unbalanced TS will most probably work with balanced TRS in that end too. One side of balanced with just be grounded which will be sensed by RME input.
Headphone is output, so no input for REV2.
