Hello all,
I am new here and I am a bit complicated because of a couple of problems in my Prophet 10 Rev 4. I had the latest firmware installed when this happened.
I was designing sounds and I pressed one button by mistake don’t remember which one exactly, and suddenly I was returned to bank 101. Then I checked the sound and I realized banks 240 to 258, and from 310 to 328 are affected, they sound weird, too high pitch in some, weird vibratos, like if all the settings were messed up, several sounded very low, and even if I moved the filter and the knobs (resonance zero even) it sounded low no matter the selected filter type, nor if I moved the oscillators and their volume to the maximum and disabled all relevant parameters (I also moved the envelope knobs), I also ensured oscillator 2 wasn’t in Lo Freq. But if I initialize that patch it sounds ok with volume (record + preset).
I tried installed the latest OS again, didn’t work, I restored factory parameters, didn’t work either. Any idea?. I don’t want to lose these patches, I had good results and a lot of work.
On the other hand, when I try to backup my sounds I open MIDI-OX and then SysEx and then “Receive Manual Dump”, but it doesn’t receive bytes and the Prophet seems not to respond. It is connected via USB, properly selected as port in MIDI devices. The Prophet on the other hand has global>MIDI SysEx as USB. The firmware re-installation worked ok so the cable is fine.
Thanks in advance for any help!.
