Trying to program change without notes playing from Korg Nautilus ...
I am trying to change programs/banks in the REV2 with my Korg Nautilus ... without having the Nautilus play the sounds from the REV2.
I have the program/banks changing fine, but need to be able to play both synths separately without the Korg controlling the REV 2 sounds from the Korg keyboard.
Sequential Rev2, Korg Nautilus, Moog Subsequent 37, Studiologic Sledge 2, Sequential Pro 3, Oberheim Matrix 6R, Behringer Monopoly, Roland D-10,Roland Alpha Juno 1, Yamaha TX81z, Rokland D-110, Yamaha TG55.
Re: Trying to program change without notes playing from Korg Nautilus ...
« Reply #1 on: December 19, 2023, 11:04:58 AM »
If the Nautilus doesn't have an option to only send program changes, you will most likely need some sort of MIDI filter in between to strip out the realtime Note On / Note Off data and pressure/velocity/mod/pitch -- but keep the program change messages.
I have all my MIDI devices routed through iConnectivity MIO XL interfaces, which have options for doing that type of filtering...  It does look like there may be other cheaper/easier options as well... haven't used these, but Miditech Thru 4 / Filter, or MIDI Solutions Event Processor might work.
Sound Sets:
jok3r
  • 369
« Reply #2 on: December 22, 2023, 02:17:25 AM »
You have to use a dedicated channel in the Nautilus mixer for your Rev2. You can configure Bank/Program changes there. Be sure to use a MIDI channel other than the Nautilus‘ keyboard channel for your Rev2. Everything should work then…
I don‘t have a Nautilus myself, but since it‘s a „smaller“ Kronos it should work in the same KORGy way. No other hardware should be needed if everything is configured right.
