I’m not sure you can, I think the transpose is effectively ‘global’ - maybe someone can correct me if wrong.
The simple workaround here though is to tune one layer one octave above or below its current settings - you can do this for the oscillators and for the samples if using both, and that should give you the desired results
It is not so simple because many programs and many of its parameters are pitch dependent...For example if the preset has filter key tracking ,sync,fm etc i ll have problem
Let’s break it down..
If you have patches where one layer has “pitch dependent” settings but the other layer does not, then make the oscillator pitch / sample pitch adjustments on the layer which does not.
For the ones where you have these types of configurations on both layers let’s break it down further:
Key tracking: after adjusting the pitches then all you have to do is adjust the cutoff value as necessary to get it sounding the same (no need to change the key tracking value).
Sync: I don’t believe any adjustment would be required here? Seeing as the oscillators would still maintain their relative differences.
FM: I haven’t explored FM on the PX so can’t say for sure.
Etc.: Is there anything else which is “pitch dependent “?
yes,i ve alread thought those ''solutions'' but the truth is that they are not the right solutions.All of them require more time,work and additional setting for something that it could be fixed with just a press of a button.
Maybe there is a way by pressing one button, but I don’t think that’s the case.
I don’t see how these are not the ‘right’ solutions. Synths work how they work, and that’s it!
An besides, it really is not that difficult to for example fix the one in regards the key tracking. Change the oscillator pitches - about a 30 second job - and then adjust the filter cutoff. It really shouldn’t take long!
Like I said I don’t think it’s a problem for synching as that relies on the relative pitches so there shouldn’t be any impact there.
And is there really anything else apart from key tracking and perhaps the FM?
EDIT - Is anyone else aware if there is a simple way to do this using transpose? I did try it out but as suspected pretty sure it’s global, plus from memory it says as much in the manual
All multitibral synths have many functions and settings that you can address easily problems like that.Those are so common features.There is a a reason that i made this thread. I do not want to spend so much time tuning the presets just to include them in a multi.I do not even want to duplicate them in different versions just because i cannot do a simple thing in a multi.
There are occassions that you want to split the keyboard and use the same patch in different octaves,in different split programs.Do you find it ok to edit the same patch all the time and resaving it in different locations?..and yes,i use fm,sync and other options a lot.
How many conversations go in synth forums:
How can I achieve this particular thing, I should like to be able to do it by x
Reply: you can achieve it, but by doing a, b and c
Response: but I want to be able to do it by x
I’m not saying what I do want and what I don’t, or how I think it should and shouldn’t work. I’m just telling you what the synth can and can’t do, as far as I know.
I could be wrong but it sounds to me that it’s actually not that big an issue in real terms to you, judging by the fact you didn’t answer any of the questions posed, but rather what you’re really after is a feature which is not available for whatever reason.
So I’ve given you ways to do what you want, if you want it to work differently then I would start a feature request thread for it.
Again to the community - does anyone know of a way to achieve this easily which I am not personally aware of to help out the op?
