Hey everyone,
A couple of months ago I bought an OB-6 module and I loooove it.
However, since a few weeks ago, whenever I play a single note multiple times in a row, every other note seems slightly pitched lower. So first note sounds normal. Second note lower. Third note normal again, fourth lower, etc.
Even with a blank patch.
When I play 2 different notes after each other, they're both the same every time I play them. But a single note will sound different every other note.
I tried re-calibrating multiple times, even reset the global settings. But it does not seem to do much. One time after re-calibrating I thought it was fixed but a day later it sounded wrong again.
The room temperature is pretty stable where my OB-6 is.
Does anyone know what I might be doing that might cause this issue?
Cheers, John
