Arpeggiator Clock Sync Issue after Patch Change
« on: September 15, 2023, 11:40:15 AM »
Hey all,
So I sequence my prophet with my Digitakt and for the most part it's a smooth operation, but when I change programs on the prophet, for some reason the clock on the prophet will jump from the Digitakt clock for like a brief second, causing a weird delay glitch if I have the delay on for the prophet program, or causing the arpeggiator to get out of sync, and having to press stop and start again on the Digitakt to resync everything. You can literally see the prophet's clock jump up maybe 5 or 6 BPMs briefly before going back to Digitakt's established tempo. It's mostly an issue for patterns where I use the prophet's arpeggiator because it won't get back in sync unless I stop and start the sequence again. I hope this makes sense. Has anyone had this issue and resolved it before?
timboréale
  • 206
  • MIDI nerd
Re: Arpeggiator Clock Sync Issue after Patch Change
« Reply #1 on: September 15, 2023, 04:49:55 PM »
It's just how the synth is. Changing programs causes the unit to re-sync the clock from scratch, which always causes a glitch.
AFAIK there is no workaround.
