Toggle navigation
Home
Help
Search
Login
Register
Login
Register
Close
Login
Remember me
SEQUENTIAL/DSI
Pro 3
(Moderator:
Paul Dither
Program sticking
Print
Pages: [
1
Program sticking
larksleep
6
Program sticking
on:
August 11, 2023, 03:16:52 PM »
I've seen this issue talked about a few times in some other places but no real solutions. My program/bank selector keeps getting stuck on a program and there's nothing I can really do to fix it beyond doing a global reset. I'm using it as my midi controller and running it directly into an Elektron Digitakt. Thoughts appreciated. Thanks.
black953mj
13
Re: Program sticking
Reply #1 on:
August 12, 2023, 10:19:51 AM »
Do you happen to have local control set to "All Off" in the global controls section? If so it will not let you change the program with the program select encoder - the program number will change but the program name and sound will remain the same. The solution would be to set it to "Keys/Wheels Off" instead. Not sure if this is your situation but thought I'd mention it in case it is. Good Luck!
larksleep
6
Reply #2 on:
August 12, 2023, 11:53:09 AM »
black953mj !!! Thanks again. Feeling somewhat stpuid about that one. Pretty sure I knew that at 1 point and forgot, lol. Hard to keep all these things straight across each synth. Anyway, I was beginning to get squirrely over it :shriek
Print
Pages: [
1
SEQUENTIAL/DSI
Pro 3
(Moderator:
Paul Dither
Program sticking
