Weird noise coming from prophet all of a sudden
« on: July 22, 2023, 09:48:18 AM »
Hello All I am getting this weird noise from my prophet rev 2.
I tried changing cables nothing.
I am running an RME Fireface UFX. I even swapped inputs with my OB6 and the same thing happened, so it's not an input issue. Even when the unit it turned off, it makes that noise.
Re: Weird noise coming from prophet all of a sudden
« Reply #1 on: July 22, 2023, 11:11:02 AM »
Noise went way when i unplugged it
shiihs
  • 103
« Reply #2 on: July 25, 2023, 11:04:19 PM »
I suspect a USB ground loop. It's an annoying problem of USB midi. If you happen to have a laptop connected to the synth, try running it on battery instead of power supply and see if the noise disappears.
links:
« Reply #3 on: April 25, 2024, 08:24:02 PM »
I tried changing cables nothing. doodle baseball
I think this problem is due to usb midi. try connecting to a synthesizer and try running it on battery instead of mains and see if the noise goes away.
