OB-X8 Firmware v. 1.10 MIDI Clock Global feature?
« on: June 27, 2023, 02:25:18 PM »
Does anyone know what this new feature does or how to turn it on? I haven't found anything in the Global menu, and no one else so far seems to have the answer for this. Arp Clock can be set to MIDI USB or DIN, as before, but LFO's still don't seem to have a way to sync to MIDI clock. So what exactly is MIDI Clock Global and what does it do? Not in the new manual either...
-AJ-
Re: OB-X8 Firmware v. 1.10 MIDI Clock Global feature?
« Reply #1 on: June 27, 2023, 07:09:24 PM »
Same.
« Reply #2 on: June 29, 2023, 07:03:47 AM »
I noticed that the 1.1.0 change log now says “Arp MIDI Clock Global” rather than “MIDI Clock Global.” So I guess that means no syncable LFO, for now at least. But the question remains - how exactly does the OB-X8 handle MIDI clock differently under 1.1.0? The arpeggiator could already sync to it. I’m not seeing anything different in any of the global menus (that I can tell at least). What am I missing here?
« Last Edit: June 29, 2023, 07:05:25 AM by Tannery Row Recording »
BT
« Reply #3 on: June 29, 2023, 11:34:03 AM »
Hi there. If you check the Arp Clock global under OS 1.1.0.0, you'll see that it covers some clocking options for the arpeggiator:
Internal - Arp is clocked from the mod box Arp Rate pot.
Clock Input - Allows the arp to receive voltage clock from the rear panel Arp input.
MIDI in DIN - Arp only receives clock from MIDI DIN input.
MIDI in USB - As above, though only via USB input.
MIDI Out DIN - Sends arp notes/clock from the arp via the DIN output.
MIDI Out USB - Sends arp notes/clock via the USB port.
« Last Edit: June 30, 2023, 10:39:29 AM by Oblong »
