TRANSPOSING SEQUENCE
W07
« on: June 05, 2023, 04:56:16 AM »
I'm preparing for a liveset, and i've curated about 32 sounds to use.
Most of them have some kind of sequence pre-programmed as well, but they are all in different keys.
What is the easiest way to transpose them all to the same key (C)?
i just want to be sure that if i hit a C note, the root note of the sequence will be in C as well.
Manually transposing 32 -sometimes 64 step sequences is a pain in the ass. I do have the editor, but a simple way to transpose the entire root note would be handy.
i know i can just transpose by hitting a key, but i don't feel like remembering  what key every sequence is in, and looking at the sequence isn't fun for on the fly improvising where everything needs to keep going
W07
Re: TRANSPOSING SEQUENCE
« Reply #1 on: June 05, 2023, 05:06:17 AM »
the shitty soundtower software sequencer editor also doesn't seem to work correctly, the sequence it shows is not the one programmed into the Pro3
  • 1800
« Reply #2 on: June 05, 2023, 10:22:55 AM »
Hold down Track Sel and the note track number at the same time. Then adjust Trk Note with the second soft knob as needed.
Prophet 5 Rev 4 #2711
MPC One+ ∙ MuseScore 4
