MPE
MPE
« on: May 31, 2023, 08:42:04 AM »
Would like to request MPE for Trigon 6 if possible! Would really open things up massively!
Kosmikos
  • 23
  • https://kosmikos.bandcamp.com
    • Kosmikos on bandcamp.com
Re: MPE
« Reply #2 on: August 19, 2023, 06:34:48 AM »
1.1.1 seems very good, just an observation, not sure if it's a bug?
Aftertouch using Channel Pressure messages is received by the Trigon but all channels/voices respond together.  The OB6's MPE implementation responds to these messages correctly, but Trigon's seems to ignore the channel and modulate all channels equally.  Sending Poly AT messages instead works ok (as it also does with the OB6), but shouldn't Channel Pressure messages also work with MPE and allow different values on each channel?  I get the same behaviour using an Osmose or a microcontroller sending midi.
